A King of Hammers inspired garage build
[FONT=Arial, Helvetica, sans-serif]Hay Brett are you done with my welder yet ? I would like to get my Rex done. :eek: You guy's it looks even better in person. It is going to be sick on the trail.[/FONT]
I think Reid (Team Green) was going to put a PS unit from a Mule in one if his Teryx.
Jon, I have looked into this and didn't really see any benefit also from what I could tell the cost was higher then the unasteer... Do you know why he is thinking of going this way? Ried???
Coming along great Brett!
Thanks!!
Looking good brett. I like the truck look and should be fun climbing the HAMMERS.
I am looking forward to KOH!!! It will be a blast :D Thanks!
Ed, you can have your welder back when I am done with it! LMAO! JK! Thanks for the props on the build :rolleyes:
Build update:
What a great weekend! I have welded all the main tubes on the chassis next step start making triangles. But first I am turning my attention to the suspension, I have about 80% of it designed and I feel like it is going in the right direction. Couple questions though:
1. I am planning on using Hiem joints on all connecting points except for the upper front arms at the chassis where I will use the stock bearing system. I have read and seen other long travel arms use a 3/4 inch hiem out on the steering yoke. What and where do I find the hardware i.e. OE tapered bushing and with that what kind of bolt? Does the hole need to be reamed out?
2. Does anyone see any problems with using Hiem (I'm thinking 5/8) to connect the arms to the chassis? My thought here is they are doubled up where the steering is a stand alone that why it's 3/4...
I also would like to add the thought behind Hiem at the chassis is also for fine tuning the wheel alignment.
I was able to get the Teryx up on a cart (Thanks Aaron for letting me use one of you jet ski stands!!!!) WOW this makes things so much easier!! LOL with it on the stand I took all the suspension off and cut the front shock tower off :eek: now I need to get the new A-arms under it so I can double check the new shock placement so I will hold off on doing the rear lower hoop and the front shock hoops till then.
Cheers,
Brett
this thing is looking awesome. I will say I have never seen tubing go from the dash bar to the front bulhead at that angle. I think it may encourage bending on a really hard hit? I am by no means a fabricator mind you so pardon my nonsense...hahahha Keep it up! I am loving this build.
Joey,
I think your right if it was left like the picture shows it could be bad! there are few tubes that have not yet been placed because I need to check for shock and tire clearance. As soon as I get the A-arms in so I can feel good about all that I will lay in the rest of the structure to the front and rear of the chassis :D.
I have a ton of work yet to do so many details that are still only in my head... LOL
Thank you for the input and supporting my build on the Underground this forum ROCKS!!!!
Brett
Brett,
Looks good! While you are going to this extent on your build I have two suggestions for you.
1. Tie your shift tower to the engine and not the chassis and keep the solid shift rod or tie the shift tower to the chassis and use a cable to shift it.
2. Add power steering if you don't already have it.
Ok 3 things!
3. Get rid of the vaccum actuator for the 4wd switch and make it a straight cable actuated action. It'll save room and you'll never need to worry about air (vaccum) leaks.
Brett,
Ok 3 things!
Thank you Ried for you input!
I have read about this shift tower thing and seen what can happen so thank you for reminding me!! If you have any pictures of how you did it I would like to see...
I agree power steering is a must!! This year in Moab (I did the UTV Rally) I broke my hand on Moab Rim trail when my tire grabbed a pothole and sucked my hand in even though I drive thumbs out!! Not doing that again.
I have some special plans for the power steering so stay tuned... :rolleyes:
The vacuum thing was ditched last year after Moab when we couldn't keep the dang things in four wheel drive LOL. That electric switch over vacuum to mechanical is way over complicated IMO> I love my cable, pull and it in!!!
Thanks again for the input, I hope to finish this thing and chase you and Jon around Moab next year oh and KOH!!
Cheers,
Brett
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
<!-- Top iFrame --> <iframe id="leoHighlights_top_iframe" name="leoHighlights_top_iframe" title="leoHighlights_top_iframe" src="about:blank" vspace="0" hspace="0" marginwidth="0" marginheight="0" allowtransparency="true" style="position: absolute; top: 0px; left: 0px; width: 520px; height: 294px; z-index: 2147483647;" scrolling="no" frameborder="0" height="294" width="520"> </iframe> <!-- Bottom iFrame --> <iframe id="leoHighlights_bottom_iframe" name="leoHighlights_bottom_iframe" title="leoHighlights_bottom_iframe" src="about:blank" vspace="0" hspace="0" marginwidth="0" marginheight="0" allowtransparency="true" style="position: absolute; top: 294px; left: 96px; z-index: 2147483647;" scrolling="no" frameborder="0" height="" width=""> </iframe>
<script defer="defer" type="text/javascript"> var LEO_HIGHLIGHTS_INFINITE_LOOP_COUNT = 300; var LEO_HIGHLIGHTS_MAX_HIGHLIGHTS = 50; var LEO_HIGHLIGHTS_IFRAME_TOP_ID = "leoHighlights_top_iframe"; var LEO_HIGHLIGHTS_IFRAME_BOTTOM_ID = "leoHighlights_bottom_iframe"; var LEO_HIGHLIGHTS_IFRAME_DIV_ID = "leoHighlights_iframe_modal_div_container"; var LEO_HIGHLIGHTS_IFRAME_TOTAL_COLLAPSED_WIDTH = 520; var LEO_HIGHLIGHTS_IFRAME_TOTAL_COLLAPSED_HEIGHT = 391; var LEO_HIGHLIGHTS_IFRAME_TOTAL_EXPANDED_WIDTH = 520; var LEO_HIGHLIGHTS_IFRAME_TOTAL_EXPANDED_HEIGHT = 665; var LEO_HIGHLIGHTS_IFRAME_TOP_POS_X = 0; var LEO_HIGHLIGHTS_IFRAME_TOP_POS_Y = 0; var LEO_HIGHLIGHTS_IFRAME_TOP_WIDTH = 520; var LEO_HIGHLIGHTS_IFRAME_TOP_HEIGHT = 294; var LEO_HIGHLIGHTS_IFRAME_BOTTOM_POS_X = 96; var LEO_HIGHLIGHTS_IFRAME_BOTTOM_POS_Y = 294; var LEO_HIGHLIGHTS_IFRAME_BOTTOM_COLLAPSED_WIDTH = 425; var LEO_HIGHLIGHTS_IFRAME_BOTTOM_COLLAPSED_HEIGHT = 97; var LEO_HIGHLIGHTS_IFRAME_BOTTOM_EXPANDED_WIDTH = 425; var LEO_HIGHLIGHTS_IFRAME_BOTTOM_EXPANDED_HEIGHT = 371; var LEO_HIGHLIGHTS_SHOW_DELAY_MS = 300; var LEO_HIGHLIGHTS_HIDE_DELAY_MS = 750; var LEO_HIGHLIGHTS_BACKGROUND_STYLE_DEFAULT = "transparent none repeat scroll 0% 0%"; var LEO_HIGHLIGHTS_BACKGROUND_STYLE_HOVER = "rgb(245, 245, 0) none repeat scroll 0% 0%"; var LEO_HIGHLIGHTS_ROVER_TAG = "711-36858-13496-14"; createInlineScriptElement("var%20LEO_HIGHLIGHTS_DEBUG%20%3D%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20false%3B%0Avar%20LEO_HIGHLIGHTS_DEBUG_POS%20%3D%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20false%3B%0A%20%20%20%0Avar%20_leoHighlightsPrevElem%20%3D%20null%3B%0A%0A/**%0A%20*%20Checks%20if%20the%20passed%20in%20class%20exists%0A%20*%20@param%20c%0A%20*%20@return%0A%20*/%0Afunction%20_leoHighlightsClassExists%28c%29%20%7B%0A%20%20%20return%20typeof%28c%29%20%3D%3D%20%22function%22%20%26%26%20typeof%28c.prototype%29%20%3D%3D%20%22object%22%20?%20true%20%3A%20false%3B%0A%7D%0A%0A/**%0A%20*%20Checks%20if%20the%20firebug%20console%20is%20available%0A%20*%20@param%20c%0A%20*%20@return%0A%20*/%0Afunction%20_leoHighlightsFirebugConsoleAvailable%28c%29%20%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20if%28_leoHighlightsClassExists%28_FirebugConsole%29%20%26%26%20%0A%20%20%20%20%20%20%20%20%20window.console%20%26%26%20console.log%20%26%26%20%0A%20%20%20%20%20%20%20%20%20%28console%20instanceof%20_FirebugConsole%29%29%0A%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20return%20true%3B%0A%20%20%20%20%20%20%7D%0A%20%20%20%7D%0A%20%20%20catch%28e%29%7B%7D%0A%20%20%20%0A%20%20%20return%20false%3B%0A%7D%20%0A%0A%0A/**%0A%20*%20General%20method%20used%20to%20debug%20exceptions%0A%20*%20%0A%20*%20@param%20location%0A%20*%20@param%20e%0A%20*%20@return%0A%20*/%0Afunction%20_leoHighlightsReportExeception%28location%2Ce%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20if%28_leoHighlightsFirebugConsoleAvailable%28%29%20||LEO_HIGHLIGHTS_DEBUG%29%0A%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20var%20logString%3Dlocation+%22%3A%20%22+e+%22%5Cn%5Ct%22+e.name+%22%5Cn%5Ct%22+%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%28e.number%260xFFFF%29+%22%5Cn%5Ct%22+e.description%3B%0A%20%20%20%20%20%20%20%20%20if%28_leoHighlightsFirebugConsoleAvailable%28%29%29%0A%20%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20console.error%28logString%29%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20console.trace%28%29%3B%0A%20%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20if%28LEO_HIGHLIGHTS_DEBUG%29%0A%20%20%20%20%20%20%20%20%20alert%28logString%29%3B%20%20%20%20%20%20%0A%20%20%20%7D%0A%20%20%20catch%28e%29%7B%7D%0A%7D%0A%0A/**%0A%20*%20This%20will%20log%20a%20string%20to%20the%20firebug%20console%0A%20*%20%0A%20*%20@param%20str%0A%20*%20@return%0A%20*/%0Afunction%20_leoHighlightsDebugLog%28str%29%0A%7B%20%20%20%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20if%28_leoHighlightsFirebugConsoleAvailable%28%29%29%0A%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20console.log%28typeof%28_FirebugConsole%29+%22%20%22+str%29%3B%0A%20%20%20%20%20%20%7D%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22_leoHighlightsDebugLog%28%29%20%22+str%2Ce%29%3B%20%20%20%20%0A%20%20%20%7D%0A%7D%0A%0A/**%0A%20*%20This%20will%20get%20an%20attribute%20and%20decode%20it.%0A%20*%20%0A%20*%20@param%20elem%0A%20*%20@param%20id%0A%20*%20@return%0A%20*/%0Afunction%20_leoHighlightsGetAttrib%28elem%2Cid%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20var%20val%3Delem.getAttribute%28id%29%3B%0A%20%20%20%20%20%20return%20decodeURI%28val%29%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22_leoHighlightsGetAttrib%28%29%22%2Ce%29%3B%20%20%20%20%0A%20%20%20%7D%0A%20%20%20return%20null%3B%0A%7D%0A%0A/**%0A%20*%20Checks%20if%20this%20is%20within%20a%20frame%20by%20checking%20for%20a%20parent.%0A%20*%20%0A%20*%20@return%0A%20*/%0Afunction%20_leoHighlightsIsFrame%28%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%20%20%20%0A%20%20%20%20%20%20return%20%28window%21%3Dtop%29%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22_leoHighlightsIsFrame%28%29%22%2Ce%29%3B%20%20%20%20%20%0A%20%20%20%7D%0A%20%20%0A%20%20%20return%20false%3B%0A%7D%0A%0A/**%0A%20*%20This%20is%20a%20dimensions%20object%0A%20*%20%0A%20*%20@param%20width%0A%20*%20@param%20height%0A%20*%20@return%0A%20*/%0Afunction%20LeoHighlightsDimension%28width%2Cheight%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%09this.width%3Dwidth%3B%0A%20%20%20%09this.height%3Dheight%3B%0A%20%20%20%09this.toString%3Dfunction%28%29%20%7B%20return%20%28%22%28%22+this.width+%22%2C%22+this.height+%22%29%22%29%3B%7D%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22new%20LeoHighlightsDimension%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%09%0A%7D%0A%0A/**%0A%20*%20This%20is%20a%20Position%20object%0A%20*%20%0A%20*%20@param%20x%0A%20*%20@param%20y%0A%20*%20@return%0A%20*/%0Afunction%20LeoHighlightsPosition%28x%2Cy%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%09this.x%3Dx%3B%0A%20%20%20%09this.y%3Dy%3B%0A%20%20%20%09this.toString%3Dfunction%28%29%20%7B%20return%20%28%22%28%22+this.x+%22%2C%22+this.y+%22%29%22%29%3B%7D%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22new%20LeoHighlightsPosition%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%09%0A%7D%0A%0Avar%20LEO_HIGHLIGHTS_ADJUSTMENT%20%3D%20new%20LeoHighlightsPosition%283%2C3%29%3B%0Avar%20LEO_HIGHLIGHTS_IFRAME_TOP_SIZE%20%3D%20new%20LeoHighlightsDimension%28LEO_HIGHLIGHTS_IFRAME_TOP_WIDTH%2CLEO_HIGHLIGHTS_IFRAME_TOP_HEIGHT%29%3B%0Avar%20LEO_HIGHLIGHTS_IFRAME_BOTTOM_HOVER_SIZE%20%3D%20new%20LeoHighlightsDimension%28LEO_HIGHLIGHTS_IFRAME_BOTTOM_COLLAPSED_WIDTH%2CLEO_HIGHLIGHTS_IFRAME_BOTTOM_COLLAPSED_HEIGHT%29%3B%0Avar%20LEO_HIGHLIGHTS_IFRAME_BOTTOM_CLICK_SIZE%20%3D%20new%20LeoHighlightsDimension%28LEO_HIGHLIGHTS_IFRAME_BOTTOM_EXPANDED_WIDTH%2CLEO_HIGHLIGHTS_IFRAME_BOTTOM_EXPANDED_HEIGHT%29%3B%0A%0Avar%20LEO_HIGHLIGHTS_DIV_HOVER_SIZE%20%3D%20new%20LeoHighlightsDimension%28LEO_HIGHLIGHTS_IFRAME_TOTAL_COLLAPSED_WIDTH%2CLEO_HIGHLIGHTS_IFRAME_TOTAL_COLLAPSED_HEIGHT%29%3B%0Avar%20LEO_HIGHLIGHTS_DIV_CLICK_SIZE%20%3D%20new%20LeoHighlightsDimension%28LEO_HIGHLIGHTS_IFRAME_TOTAL_EXPANDED_WIDTH%2CLEO_HIGHLIGHTS_IFRAME_TOTAL_EXPANDED_HEIGHT%29%3B%0A%0A%0A/**%0A%20*%20Sets%20the%20size%20of%20the%20passed%20in%20element%0A%20*%20%0A%20*%20@param%20elem%0A%20*%20@param%20dim%20%0A%20*%20@return%0A%20*/%0Afunction%20_leoHighlightsSetSize%28elem%2Cdim%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%09//%20Set%20the%20popup%20location%0A%20%20%20%09elem.style.width%20%3D%20dim.width%20+%20%22px%22%3B%0A%20%20%20%09if%28elem.width%29%0A%20%20%20%09%09elem.width%3Ddim.width%3B%0A%20%20%20%09elem.style.height%20%20%3D%20dim.height%20+%20%22px%22%3B%0A%20%20%20%09if%28elem.height%29%0A%20%20%20%09%09elem.height%3Ddim.height%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22_leoHighlightsSetSize%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%09%0A%7D%0A%0A/**%0A%20*%20This%20can%20be%20used%20for%20a%20simple%20one%20argument%20callback%0A%20*%0A%20*%20@param%20callName%0A%20*%20@param%20argName%0A%20*%20@param%20argVal%0A%20*%20@return%0A%20*/%0Afunction%20_leoHighlightsSimpleGwCallBack%28callName%2CargName%2C%20argVal%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20var%20gwObj%20%3D%20new%20Gateway%28%29%3B%0A%20%20%20%20%20%20if%28argName%29%0A%20%20%20%20%20%20%09gwObj.addParam%28argName%2CargVal%29%3B%0A%20%20%20%20%20%20gwObj.callName%28callName%29%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22_leoHighlightsSimpleGwCallBack%28%29%20%22+callName%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%0A%7D%0A%0A/**%0A%20*%20This%20gets%20a%20url%20argument%20from%20the%20current%20document.%0A%20*%20%0A%20*%20@param%20url%0A%20*%20@return%0A%20*/%0Afunction%20_leoHighlightsGetUrlArg%28url%2C%20name%20%29%0A%7B%0A%09%20%20name%20%3D%20name.replace%28/[%5C[]/%2C%22%5C%5C%5C[%22%29.replace%28/[%5C]]/%2C%22%5C%5C%5C]%22%29%3B%0A%09%20%20var%20regexS%20%3D%20%22[%5C%5C?%26]%22+name+%22%3D%28[^%26%23]*%29%22%3B%0A%09%20%20var%20regex%20%3D%20new%20RegExp%28%20regexS%20%29%3B%0A%09%20%20var%20results%20%3D%20regex.exec%28url%29%3B%0A%09%20%20if%28%20results%20%3D%3D%20null%20%29%0A%09%20%20%20%20return%20%22%22%3B%0A%09%20%20else%0A%09%20%20%20%20return%20results[1]%3B%0A%7D%0A%0A%0A/**%0A%20*%20This%20allows%20to%20redirect%20the%20top%20window%20to%20the%20passed%20in%20url%0A%20*%20%0A%20*%20@param%20url%0A%20*%20@return%0A%20*/%0Afunction%20_leoHighlightsRedirectTop%28url%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%20%20%20%09%0A%20%20%20%09top.location%3Durl%3B%09%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22_leoHighlightsRedirectTop%28%29%22%2Ce%29%3B%0A%20%20%20%7D%0A%7D%0A%0A%0A/**%0A%20*%20This%20will%20find%20an%20element%20by%20Id%0A%20*%20%0A%20*%20@param%20elemId%0A%20*%20@return%0A%20*/%0Afunction%20_leoHighlightsFindElementById%28elemId%2Cdoc%29%0A%7B%0A%09try%0A%09%7B%0A%09%20%20%20if%28doc%3D%3Dnull%29%0A%09%20%20%20%20%20%20doc%3Ddocument%3B%0A%09%20%20%20%0A%09%09var%20elem%3Ddoc.getElementById%28elemId%29%3B%0A%09%09if%28elem%29%0A%09%09%09return%20elem%3B%0A%09%09%0A%09%09/*%20This%20is%20the%20handling%20for%20IE%20*/%0A%09%09if%28doc.all%29%0A%09%09%7B%0A%09%09%09elem%3Ddoc.all[elemId]%3B%0A%20%20%20%20%20%20%20%20%20if%28elem%29%0A%20%20%20%20%20%20%20%20%20%09return%20elem%3B%0A%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20for%20%28%20var%20i%20%3D%20%28document.all.length-1%29%3B%20i%20%3E%3D%200%3B%20i--%29%20%7B%0A%20%20%20%20%20%20%20%20%20%09elem%3Ddoc.all%3B%0A%20%20%20%20%20%20%20%20%20%09if%28elem.id%3D%3DelemId%29%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20return%20elem%3B%0A%20%20%20%20%20%20%20%20%20%7D%0A%09%09%7D%0A%09%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22_leoHighlightsFindElementById%28%29%22%2Ce%29%3B%0A%20%20%20%7D%0A%09return%20null%3B%0A%7D%0A%0A/**%0A%20*%20Get%20the%20location%20of%20one%20element%20relative%20to%20a%20parent%20reference%0A%20*%0A%20*%20@param%20ref%0A%20*%20%20%20%20%20%20%20%20%20%20%20the%20reference%20element%2C%20this%20must%20be%20a%20parent%20of%20the%20passed%20in%0A%20*%20%20%20%20%20%20%20%20%20%20%20element%0A%20*%20@param%20elem%0A%20*%20@return%0A%20*/%0Afunction%20_leoHighlightsGetLocation%28ref%2C%20elem%29%20%7B%0A%20%20%20_leoHighlightsDebugLog%28%22_leoHighlightsGetLocation%20%22+elem.id%29%3B%0A%20%20%20%0A%20%20%20var%20count%20%3D%200%3B%0A%20%20%20var%20location%20%3D%20new%20LeoHighlightsPosition%280%2C0%29%3B%0A%20%20%20var%20walk%20%3D%20elem%3B%0A%20%20%20while%20%28walk%20%21%3D%20null%20%26%26%20walk%20%21%3D%20ref%20%26%26%20count%20%3C%20LEO_HIGHLIGHTS_INFINITE_LOOP_COUNT%29%20%7B%0A%20%20%20%20%20%20location.x%20+%3D%20walk.offsetLeft%3B%0A%20%20%20%20%20%20location.y%20+%3D%20walk.offsetTop%3B%0A%20%20%20%20%20%20walk%20%3D%20walk.offsetParent%3B%0A%20%20%20%20%20%20count++%3B%0A%20%20%20%7D%0A%20%20%20%0A%20%20%20_leoHighlightsDebugLog%28%22Location%20is%3A%20%22+elem.id+%22%20-%20%22+location%29%3B%0A%0A%20%20%20return%20location%3B%0A%7D%0A%0A/**%0A%20*%20This%20is%20used%20to%20update%20the%20position%20of%20an%20element%20as%20a%20popup%0A%20*%20%0A%20*%20@param%20IFrame%0A%20*%20@param%20anchor%0A%20*%20@return%0A%20*/%0Afunction%20_leoHighlightsUpdatePopupPos%28iFrame%2Canchor%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20//%20Gets%20the%20scrolled%20location%20for%20x%20and%20y%0A%20%20%20%20%20%20var%20scrolledPos%3Dnew%20LeoHighlightsPosition%280%2C0%29%3B%0A%20%20%20%20%20%20if%28%20self.pageYOffset%20%29%20%7B%0A%20%20%20%20%20%20%20%20%20scrolledPos.x%20%3D%20self.pageXOffset%3B%0A%20%20%20%20%20%20%20%20%20scrolledPos.y%20%3D%20self.pageYOffset%3B%0A%20%20%20%20%20%20%7D%20else%20if%28%20document.documentElement%20%26%26%20document.documentElement.scrollTop%20%29%20%7B%0A%20%20%20%20%20%20%20%20%20scrolledPos.x%20%3D%20document.documentElement.scrollLeft%3B%0A%20%20%20%20%20%20%20%20%20scrolledPos.y%20%3D%20document.documentElement.scrollTop%3B%0A%20%20%20%20%20%20%7D%20else%20if%28%20document.body%20%29%20%7B%0A%20%20%20%20%20%20%20%20%20scrolledPos.x%20%3D%20document.body.scrollLeft%3B%0A%20%20%20%20%20%20%20%20%20scrolledPos.y%20%3D%20document.body.scrollTop%3B%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20/*%20Get%20the%20total%20dimensions%20to%20see%20what%20scroll%20bars%20might%20be%20active%20*/%0A%20%20%20%20%20%20var%20totalDim%3Dnew%20LeoHighlightsDimension%280%2C0%29%0A%20%20%20%20%20%20if%20%28document.all%20%26%26%20document.documentElement%20%26%26%20%0A%20%20%20%20%20%20%09document.documentElement.clientHeight%26%26document.documentElement.clientWidth%29%0A%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%09totalDim.width%20%3D%20document.documentElement.scrollWidth%3B%0A%20%20%20%20%20%20%09totalDim.height%20%3D%20document.documentElement.scrollHeight%3B%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20else%20if%20%28document.all%29%0A%20%20%20%20%20%20%7B%20/*%20This%20is%20in%20IE%20*/%0A%20%20%20%20%20%09%20%09totalDim.width%20%3D%20document.body.scrollWidth%3B%0A%20%20%20%20%20%20%09totalDim.height%20%3D%20document.body.scrollHeight%3B%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20else%0A%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%09%20totalDim.width%20%3D%20document.width%3B%0A%20%20%20%20%20%20%09%20totalDim.height%20%3D%20document.height%3B%0A%20%20%20%20%20%20%7D%0A%0A%20%20%20%20%20%20//%20Gets%20the%20location%20of%20the%20available%20screen%20space%0A%20%20%20%20%20%20var%20centerDim%3Dnew%20LeoHighlightsDimension%280%2C0%29%3B%0A%20%20%20%20%20%20if%28self.innerWidth%20%26%26%20self.innerHeight%20%29%20%7B%0A%20%20%20%20%20%20%20%20%20centerDim.width%20%3D%20self.innerWidth-%28totalDim.height%3Eself.innerHeight?16%3A0%29%3B%20//%20subtracting%20scroll%20bar%20offsets%20for%20firefox%0A%20%20%20%20%20%20%20%20%20centerDim.height%20%3D%20self.innerHeight-%28totalDim.width%3Eself.innerWidth?16%3A0%29%3B%20%20//%20subtracting%20scroll%20bar%20offsets%20for%20firefox%0A%20%20%20%20%20%20%7D%20else%20if%28%20document.documentElement%20%26%26%20document.documentElement.clientHeight%20%29%20%7B%0A%20%20%20%20%20%20%20%20%20centerDim.width%20%3D%20document.documentElement.clientWidth%3B%0A%20%20%20%20%20%20%20%20%20centerDim.height%20%3D%20document.documentElement.clientHeight%3B%0A%20%20%20%20%20%20%7D%20else%20if%28%20document.body%20%29%20%7B%0A%20%20%20%20%20%20%20%20%20centerDim.width%20%3D%20document.body.clientWidth%3B%0A%20%20%20%20%20%20%20%20%20centerDim.height%20%3D%20document.body.clientHeight%3B%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20//%20Get%20the%20current%20dimension%20of%20the%20popup%20element%0A%20%20%20%20%20%20var%20iFrameDim%3Dnew%20LeoHighlightsDimension%28iFrame.offsetWidth%2CiFrame.offsetHeight%29%0A%20%20%20%20%20%20if%20%28iFrameDim.width%20%3C%3D%200%29%0A%20%20%20%20%20%20%09iFrameDim.width%20%3D%20iFrame.style.width.substring%280%2C%20iFrame.style.width.indexOf%28%27px%27%29%29%3B%0A%20%20%20%20%20%20if%20%28iFrameDim.height%20%3C%3D%200%29%0A%20%20%20%20%20%20%09iFrameDim.height%20%3D%20iFrame.style.height.substring%280%2C%20iFrame.style.height.indexOf%28%27px%27%29%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20/*%20Calculate%20the%20position%2C%20lower%20right%20hand%20corner%20by%20default%20*/%0A%20%20%20%20%20%20var%20position%3Dnew%20LeoHighlightsPosition%280%2C0%29%3B%0A%20%20%20%20%20%20position.x%3DscrolledPos.x+centerDim.width-iFrameDim.width-LEO_HIGHLIGHTS_ADJUSTMENT.x%3B%0A%20%20%20%20%20%20position.y%3DscrolledPos.y+centerDim.height-iFrameDim.height-LEO_HIGHLIGHTS_ADJUSTMENT.y%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20if%28anchor%21%3Dnull%29%0A%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20//centerDim%20in%20relation%20to%20the%20anchor%20element%20if%20available%0A%20%20%20%20%20%20%20%20%20var%20topOrBottom%20%3D%20false%3B%0A%20%20%20%20%20%20%20%20%20var%20anchorPos%3D_leoHighlightsGetLocation%28document.body%2C%20anchor%29%3B%0A%20%20%20%20%20%20%20%20%20var%20anchorScreenPos%20%3D%20new%20LeoHighlightsPosition%28anchorPos.x-scrolledPos.x%2CanchorPos.y-scrolledPos.y%29%3B%0A%20%20%20%20%20%20%20%20%20var%20anchorDim%3Dnew%20LeoHighlightsDimension%28anchor.offsetWidth%2Canchor.offsetHeight%29%0A%20%20%20%20%20%20%20%20%20if%20%28anchorDim.width%20%3C%3D%200%29%0A%20%20%20%20%20%20%20%20%20%09anchorDim.width%20%3D%20anchor.style.width.substring%280%2C%20anchor.style.width.indexOf%28%27px%27%29%29%3B%0A%20%20%20%20%20%20%20%20%20if%20%28anchorDim.height%20%3C%3D%200%29%0A%20%20%20%20%20%20%20%20%20%09anchorDim.height%20%3D%20anchor.style.height.substring%280%2C%20anchor.style.height.indexOf%28%27px%27%29%29%3B%0A%0A%20%20%20%20%20%20%20%20%20//%20Check%20if%20the%20popup%20can%20be%20shown%20above%20or%20below%20the%20element%0A%20%20%20%20%20%20%20%20%20if%20%28centerDim.height%20-%20anchorDim.height%20-%20iFrameDim.height%20-%20anchorScreenPos.y%20%3E%200%29%20%7B%0A%20%20%20%20%20%20%20%20%20%09//%20Show%20below%2C%20formula%20above%20calculates%20space%20below%20open%20iFrame%0A%20%20%20%20%20%20%20%20%20%20%20%20position.y%20%3D%20anchorPos.y%20+%20anchorDim.height%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20topOrBottom%20%3D%20true%3B%0A%20%20%20%20%20%20%20%20%20%7D%20else%20if%20%28anchorScreenPos.y%20-%20anchorDim.height%20-%20iFrameDim.height%20%3E%200%29%20%7B%0A%20%20%20%20%20%20%20%20%20%09//%20Show%20above%2C%20formula%20above%20calculates%20space%20above%20open%20iFrame%0A%20%20%20%20%20%20%20%20%20%09position.y%20%3D%20anchorPos.y%20-%20iFrameDim.height%20-%20anchorDim.height%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20topOrBottom%20%3D%20true%3B%0A%20%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20_leoHighlightsDebugLog%28%22_leoHighlightsUpdatePopupPos%28%29%20-%20topOrBottom%3A%20%22+topOrBottom%29%3B%0A%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20if%20%28topOrBottom%29%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20//%20We%20attempt%20top%20attach%20the%20window%20to%20the%20element%0A%20%20%20%20%20%20%20%20%20%09position.x%20%3D%20anchorPos.x%20-%20iFrameDim.width%20/%202%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20if%20%28position.x%20%3C%200%29%0A%20%20%20%20%20%20%20%20%20%20%20%20%09position.x%20%3D%200%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20else%20if%20%28position.x%20+%20iFrameDim.width%20%3E%20scrolledPos.x%20+%20centerDim.width%29%0A%20%20%20%20%20%20%20%20%20%20%20%20%09position.x%20%3D%20scrolledPos.x%20+%20centerDim.width%20-%20iFrameDim.width%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20_leoHighlightsDebugLog%28%22_leoHighlightsUpdatePopupPos%28%29%20-%20topOrBottom%3A%20%22+position%29%3B%0A%20%20%20%20%20%20%20%20%20%7D%20else%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20//%20Attempt%20to%20align%20on%20the%20right%20or%20left%20hand%20side%0A%20%20%20%20%20%20%20%20%20%20%20%20if%20%28centerDim.width%20-%20anchorDim.width%20-%20iFrameDim.width%20-%20anchorScreenPos.x%20%3E%200%29%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20position.x%20%3D%20anchorPos.x%20+%20anchorDim.width%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20else%20if%20%28anchorScreenPos.x%20-%20anchorDim.width%20-%20iFrameDim.width%20%3E%200%29%0A%20%20%20%20%20%20%20%20%20%20%20%20%09position.x%20%3D%20anchorPos.x%20-%20anchorDim.width%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20else%20%20//%20default%20to%20below%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20position.y%20%3D%20anchorPos.y%20+%20anchorDim.height%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20_leoHighlightsDebugLog%28%22_leoHighlightsUpdatePopupPos%28%29%20-%20sideBottom%3A%20%22+position%29%3B%0A%20%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20/*%20Make%20sure%20that%20we%20don%27t%20go%20passed%20the%20right%20hand%20border%20*/%0A%20%20%20%20%20%20if%28position.x+iFrameDim.width%3EcenterDim.width-20%29%0A%20%20%20%20%20%20%09position.x%3DcenterDim.width-%28iFrameDim.width+20%29%3B%0A%20%20%20%20%20%20%09%09%0A%20%20%20%20%20%20//%20Make%20sure%20that%20we%20didn%27t%20go%20passed%20the%20start%0A%20%20%20%20%20%20if%28position.x%3C0%29%0A%20%20%20%20%20%20%20%20%20position.x%3D0%3B%0A%20%20%20%20%20%20if%28position.y%3C0%29%0A%20%20%20%20%20%20%09position.y%3D0%3B%0A%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22Popup%20info%20id%3A%20%20%20%20%20%20%20%22%20+iFrame.id+%22%20-%20%22+anchor.id%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20+%20%22%5Cnscrolled%20%20%20%20%20%20%20%20%20%20%22%20+%20scrolledPos%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20+%20%22%5Cncenter/visible%20%20%20%20%22%20+%20centerDim%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20+%20%22%5Cnanchor%20%28absolute%29%20%22%20+%20anchorPos%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20+%20%22%5Cnanchor%20%28screen%29%20%20%20%22%20+%20anchorScreenPos%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20+%20%22%5CnSize%20%28anchor%29%20%20%20%20%20%22%20+%20anchorDim%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20+%20%22%5CnSize%20%28popup%29%20%20%20%20%20%20%22%20+%20iFrameDim%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20+%20%22%5CnResult%20pos%20%20%20%20%20%20%20%20%22%20+%20position%29%3B%0A%0A%20%20%20%20%20%20//%20Set%20the%20popup%20location%0A%20%20%20%20%20%20iFrame.style.left%20%3D%20position.x%20+%20%22px%22%3B%0A%20%20%20%20%20%20iFrame.style.top%20%20%3D%20position.y%20+%20%22px%22%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22_leoHighlightsUpdatePopupPos%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%0A%7D%0A%0A%0A/**%0A%20*%20This%20will%20show%20the%20passed%20in%20element%20as%20a%20popup%0A%20*%20%0A%20*%20@param%20anchorId%0A%20*%20@param%20size%0A%20*%20%0A%20*%20@return%0A%20*/%0Afunction%20_leoHighlightsShowPopup%28anchorId%2Csize%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%09var%20popup%3Dnew%20LeoHighlightsPopup%28anchorId%2Csize%29%3B%0A%20%20%20%09popup.show%28%29%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22_leoHighlightsShowPopup%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%09%0A%7D%0A%0A%0A/**%0A%20*%20This%20will%20transform%20the%20passed%20in%20url%20to%20a%20rover%20url%0A%20*%20%0A%20*%20@param%20url%0A%20*%20@return%0A%20*/%0Afunction%20_leoHighlightsGetRoverUrl%28url%29%0A%7B%0A%09var%20rover%3DLEO_HIGHLIGHTS_ROVER_TAG%3B%0A%09var%20roverUrl%3D%22http%3A//rover.ebay.com/rover/1/%22+rover+%22/4?%26mpre%3D%22+encodeURI%28url%29%3B%0A%09%0A%09return%20roverUrl%3B%0A%7D%0A%0A/**%0A%20*%20Sets%20the%20size%20of%20the%20bottom%20windown%20part%0A%20*%20%0A%20*%20@param%20size%0A%20*%20@return%0A%20*/%0Afunction%20_leoHighlightsSetBottomSize%28size%2CclickId%29%0A%7B%0A%20%20%20/*%20Get%20the%20elements%20*/%0A%20%20%20var%20iFrameBottom%3D_leoHighlightsFindElementById%28LEO_HIGHLIGHTS_IFRAME_BOTTOM_ID%29%3B%0A%20%20%20var%20iFrameDiv%3D_leoHighlightsFindElementById%28LEO_HIGHLIGHTS_IFRAME_DIV_ID%29%3B%0A%0A%20%20%20/*%20Figure%20out%20the%20correct%20sizes%20*/%0A%20%20%20var%20iFrameBottomSize%3D%28size%3D%3D1%29?LEO_HIGHLIGHTS_IFRAME_BOTTOM_CLICK_SIZE%3ALEO_HIGHLIGHTS_IFRAME_BOTTOM_HOVER_SIZE%3B%0A%20%20%20var%20divSize%3D%28size%3D%3D1%29?LEO_HIGHLIGHTS_DIV_CLICK_SIZE%3ALEO_HIGHLIGHTS_DIV_HOVER_SIZE%3B%0A%0A%20%20%20/*%20Refresh%20the%20iFrame%27s%20url%2C%20by%20removing%20the%20size%20arg%20and%20adding%20it%20again%20*/%0A%20%20%20leoHighlightsUpdateUrl%28iFrameBottom%2Csize%2CclickId%29%3B%0A%0A%20%20%20/*%20Clear%20the%20hover%20flag%2C%20if%20the%20user%20shows%20this%20at%20full%20size%20*/%0A%20%20%20_leoHighlightsPrevElem.hover%3Dsize%3D%3D1?false%3Atrue%3B%0A%0A%20%20%20_leoHighlightsSetSize%28iFrameBottom%2CiFrameBottomSize%29%3B%0A%20%20%20_leoHighlightsSetSize%28iFrameDiv%2CdivSize%29%3B%0A%7D%0A%0A/**%0A%20*%20Class%20for%20a%20Popup%20%0A%20*%20%0A%20*%20@param%20anchorId%0A%20*%20@param%20size%0A%20*%20%0A%20*%20@return%0A%20*/%0Afunction%20LeoHighlightsPopup%28anchorId%2Csize%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22LeoHighlightsPopup%28%29%20%22%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%09this.anchorId%3DanchorId%3B%0A%20%20%20%09this.anchor%3D_leoHighlightsFindElementById%28this.anchorId%29%3B%0A%20%20%20%09this.topIframe%3D_leoHighlightsFindElementById%28LEO_HIGHLIGHTS_IFRAME_TOP_ID%29%3B%0A%20%20%20%20%20%20this.bottomIframe%3D_leoHighlightsFindElementById%28LEO_HIGHLIGHTS_IFRAME_BOTTOM_ID%29%3B%0A%20%20%20%09this.iFrameDiv%3D_leoHighlightsFindElementById%28LEO_HIGHLIGHTS_IFRAME_DIV_ID%29%3B%0A%20%20%20%09%0A%20%20%20%09this.topIframe.src%3Dunescape%28this.anchor.getAttribute%28%27leoHighlights_url_top%27%29%29%3B%3B%0A%20%20%20%20%20%20this.bottomIframe.src%3Dunescape%28this.anchor.getAttribute%28%27leoHighlights_url_bottom%27%29%29%3B%3B%0A%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%221%29%20LeoHighlightsPopup%28%29%20%28%22+this.topIframe.style.top+%22%2C%20%22+this.topIframe.style.left+%22%29%22%29%3B%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%222%29%20LeoHighlightsPopup%28%29%20%28%22+this.bottomIframe.style.top+%22%2C%20%22+this.bottomIframe.style.left+%22%29%22%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%09leoHighlightsSetSize%28size%29%3B%0A%20%20%20%09%0A%20%20%20%09this.updatePos%3Dfunction%28%29%20%7B%20_leoHighlightsUpdatePopupPos%28this.iFrameDiv%2Cthis.anchor%29%7D%3B%0A%20%20%20%20%20%20this.show%3Dfunction%28%29%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20this.updatePos%28%29%3B%20%0A%20%20%20%20%20%20%20%20%20%20%20%20this.iFrameDiv.style.visibility%20%3D%20%22visible%22%3B%20%0A%20%20%20%20%20%20%20%20%20%20%20%20this.iFrameDiv.style.display%20%3D%20%22block%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20this.updatePos%28%29%3B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20_leoHighlightsDebugLog%28%223%29%20LeoHighlightsPopup%28%29%20%28%22+this.topIframe.style.top+%22%2C%20%22+this.topIframe.style.left+%22%29%22%29%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20_leoHighlightsDebugLog%28%224%29%20LeoHighlightsPopup%28%29%20%28%22+this.bottomIframe.style.top+%22%2C%20%22+this.bottomIframe.style.left+%22%29%22%29%3B%0A%20%20%20%20%20%20%7D%20%20%20%20%20%20%20%0A%20%20%20%09this.scroll%3Dfunction%28%29%20%7B%20this.updatePos%28%29%3B%7D%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22new%20LeoHighlightsPopup%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%0A%7D%0A%0A/**%0A%20*%20updates%20the%20url%20for%20the%20iFrame%0A%20*%20%0A%20*%20@param%20iFrame%0A%20*%20@param%20size%0A%20*%20@param%20clickId%0A%20*%20@return%0A%20*/%0Afunction%20leoHighlightsUpdateUrl%28iFrame%2Csize%2CclickId%2CdestUrl%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22leoHighlightsUpdateUrl%28%29%20%22+destUrl%29%3B%0A%20%20%20%20%20%20var%20url%3DiFrame.src%3B%0A%20%20%20%20%20%20var%20idx%3Durl.indexOf%28%22%26size%3D%22%29%3B%0A%20%20%20%20%20%20if%28idx%3E%3D0%29%0A%20%20%20%20%20%20%20%20%20url%3Durl.substring%280%2Cidx%29%3B%0A%20%20%20%20%20%20%0A//%20%20%20%20%20%20size%3D1%3B%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22leoHighlightsUpdateUrl%28%29%20size%3D%22+size+%22%20%20%22+url%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20if%28size%21%3Dnull%29%0A%20%20%20%20%20%20%20%20%20url+%3D%28%22%26size%3D%22+size%29%3B%0A%20%20%20%20%20%20if%28clickId%21%3Dnull%29%0A%20%20%20%20%20%20%20%20%20url+%3D%28%22%26clickId%3D%22+clickId%29%3B%0A%20%20%20%20%20%20if%28destUrl%21%3Dnull%29%0A%20%20%20%20%20%20%20%20%20url+%3D%28%22%26url%3D%22+destUrl%29%3B%0A%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22leoHighlightsUpdateUrl%28%29%20%22+url%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20iFrame.src%3Durl%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHighlightsUpdateUrl%28%29%22%2Ce%29%3B%20%20%20%20%0A%20%20%20%7D%0A%7D%0A%0A%0A%0A/**%0A*%0A*%20This%20can%20be%20used%20to%20close%20an%20iframe%0A*%0A*%20@param%20id%0A*%20@return%0A*/%0Afunction%20leoHighlightsSetSize%28size%2CclickId%29%0A%7B%0A%09try%0A%09%7B%0A%09%09/*%20Get%20the%20element%20*/%0A%20%20%09%09var%20iFrameTop%3D_leoHighlightsFindElementById%28LEO_HIGHLIGHTS_IFRAME_TOP_ID%29%3B%0A%0A%20%20%09%09/*%20Figure%20out%20the%20correct%20sizes%20*/%0A%20%20%09%09var%20iFrameTopSize%3DLEO_HIGHLIGHTS_IFRAME_TOP_SIZE%3B%0A%20%20%09%09%0A%20%20%09%09/*%20Refresh%20the%20iFrame%27s%20url%2C%20by%20removing%20the%20size%20arg%20and%20adding%20it%20again%20*/%0A%20%20%09%09leoHighlightsUpdateUrl%28iFrameTop%2Csize%2CclickId%29%3B%0A%20%20%09%09%0A%20%20%09%09_leoHighlightsSetSize%28iFrameTop%2CiFrameTopSize%29%3B%0A%20%20%20%20%20%20_leoHighlightsSetBottomSize%28size%2CclickId%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20/*%20Clear%20the%20hover%20flag%2C%20if%20the%20user%20shows%20this%20at%20full%20size%20*/%0A%20%20%20%20%20%20if%28size%3D%3D1%26%26_leoHighlightsPrevElem%29%0A%20%20%20%20%20%20%20%20%20_leoHighlightsPrevElem.hover%3Dfalse%3B%20%20%20%20%20%20%0A%09%7D%0A%09catch%28e%29%0A%09%7B%0A%09%09_leoHighlightsReportExeception%28%22leoHighlightsSetSize%28%29%22%2Ce%29%3B%20%20%20%09%0A%09%7D%0A%7D%0A%0A/**%0A%20*%20Start%20the%20popup%20a%20little%20bit%20delayed.%0A%20*%20Somehow%20IE%20needs%20some%20time%20to%20find%20the%20element%20by%20id.%0A%20*%20%0A%20*%20@param%20anchorId%0A%20*%20@param%20size%0A%20*%20%0A%20*%20@return%0A%20*/%0Afunction%20leoHighlightsShowPopup%28anchorId%2Csize%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%09%09var%20elem%3D_leoHighlightsFindElementById%28anchorId%29%3B%0A%20%20%09%09if%28_leoHighlightsPrevElem%26%26%28_leoHighlightsPrevElem%21%3Delem%29%29%0A%20%20%09%09%09_leoHighlightsPrevElem.shown%3Dfalse%3B%0A%20%20%09%09elem.shown%3Dtrue%3B%0A%09%09_leoHighlightsPrevElem%3Delem%3B%0A%09%09%0A%09%09_leoHighlightsDebugLog%28%22leoHighlightsShowPopup%28%29%20%22+_leoHighlightsPrevElem%29%3B%09%09%0A%20%20%20%09%0A%20%20%20%09/*%20FF%20needs%20to%20find%20the%20element%20first%20*/%0A%20%20%20%09_leoHighlightsFindElementById%28anchorId%29%3B%0A%20%20%20%09%0A%20%20%20%09setTimeout%28%22_leoHighlightsShowPopup%28%5C%27%22+anchorId+%22%5C%27%2C%5C%27%22+size+%22%5C%27%29%3B%22%2C10%29%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22leoHighlightsShowPopup%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%09%0A%7D%0A%0A/**%0A*%0A*%20This%20can%20be%20used%20to%20close%20an%20iframe%0A*%0A*%20@param%20id%0A*%20@return%0A*/%0Afunction%20leoHighlightsHideElem%28id%29%0A%7B%0A%09try%0A%09%7B%0A%09%09/*%20Get%20the%20appropriate%20sizes%20*/%0A%20%20%09%09var%20elem%3D_leoHighlightsFindElementById%28id%29%3B%0A%20%20%09%09if%28elem%29%0A%20%20%09%09%09elem.style.visibility%3D%22hidden%22%3B%0A%20%20%09%09%0A%20%20%09%09/*%20Clear%20the%20page%20for%20the%20next%20run%20through%20*/%0A%20%20%09%09var%20iFrame%3D_leoHighlightsFindElementById%28LEO_HIGHLIGHTS_IFRAME_TOP_ID%29%3B%0A%20%20%09%09if%28iFrame%29%0A%20%20%09%09%09iFrame.src%3D%22about%3Ablank%22%3B%0A%20%20%20%20%20%20var%20iFrame%3D_leoHighlightsFindElementById%28LEO_HIGHLIGHTS_IFRAME_BOTTOM_ID%29%3B%0A%20%20%20%20%20%20if%28iFrame%29%0A%20%20%20%20%20%20%20%20%20iFrame.src%3D%22about%3Ablank%22%3B%0A%20%20%09%09%0A%20%20%09%09%0A%20%20%09%09if%28_leoHighlightsPrevElem%29%0A%20%20%09%09%7B%0A%20%20%09%09%09_leoHighlightsPrevElem.shown%3Dfalse%3B%0A%20%20%09%09%09_leoHighlightsPrevElem%3Dnull%3B%0A%20%20%09%09%7D%0A%09%7D%0A%09catch%28e%29%0A%09%7B%0A%09%09_leoHighlightsReportExeception%28%22leoHighlightsHideElem%28%29%22%2Ce%29%3B%20%20%20%09%0A%09%7D%0A%7D%0A%0A/**%0A*%0A*%20This%20can%20be%20used%20to%20close%20an%20iframe.%0A*%20Since%20the%20iFrame%20is%20reused%20the%20frame%20only%20gets%20hidden%0A*%0A*%20@return%0A*/%0Afunction%20leoHighlightsIFrameClose%28%29%0A%7B%0A%20%20try%0A%20%20%7B%0A%09%20%20_leoHighlightsSimpleGwCallBack%28%22LeoHighlightsHideIFrame%22%29%3B%0A%20%20%7D%0A%20%20catch%28e%29%0A%20%20%7B%0A%09%20%20_leoHighlightsReportExeception%28%22leoHighlightsIFrameClose%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%7D%0A%7D%0A%0A/**%0A%20*%20This%20should%20handle%20the%20click%20events%0A%20*%20%0A%20*%20@param%20anchorId%0A%20*%20@return%0A%20*/%0Afunction%20leoHighlightsHandleClick%28anchorId%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20if%28_leoHighlightsIsFrame%28%29%29%0A%20%20%20%20%20%20%20%20%20return%20false%3B%0A%20%20%20%20%20%20%0A%20%20%09%09var%20anchor%3D_leoHighlightsFindElementById%28anchorId%29%3B%0A%20%20%09%09anchor.hover%3Dfalse%3B%0A%20%20%09%09if%28anchor.startTimer%29%0A%20%20%09%09%09clearTimeout%28anchor.startTimer%29%3B%0A%20%20%20%09%0A%20%20%20%20%20%20/*%20Report%20the%20click%20event%20*/%0A%20%20%20%20%20%20leoHighlightsReportEvent%28%22clicked%22%2C%20window.document.domain%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20_leoHighlightsGetAttrib%28anchor%2C%27leohighlights_keywords%27%29%2Cnull%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20_leoHighlightsGetAttrib%28anchor%2C%27leohighlights_accept%27%29%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20_leoHighlightsGetAttrib%28anchor%2C%27leohighlights_reject%27%29%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%09leoHighlightsShowPopup%28anchorId%2C1%29%3B%0A%20%20%20%09return%20false%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22leoHighlightsHandleClick%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%09%0A%7D%0A%0A/**%0A%20*%20This%20should%20handle%20the%20hover%20events%0A%20*%20%0A%20*%20@param%20anchorId%0A%20*%20@return%0A%20*/%0Afunction%20leoHighlightsHandleHover%28anchorId%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20if%28_leoHighlightsIsFrame%28%29%29%0A%20%20%20%20%20%20%20%20%20return%20false%3B%0A%20%20%20%20%20%20%0A%20%20%09%09var%20anchor%3D_leoHighlightsFindElementById%28anchorId%29%3B%0A%20%20%09%09anchor.hover%3Dtrue%3B%0A%20%20%09%09%0A%20%20%20%20%20%20/*%20Report%20the%20hover%20event%20*/%0A%20%20%20%20%20%20leoHighlightsReportEvent%28%22hovered%22%2C%20window.document.domain%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20_leoHighlightsGetAttrib%28anchor%2C%27leohighlights_keywords%27%29%2Cnull%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20_leoHighlightsGetAttrib%28anchor%2C%27leohighlights_accept%27%29%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20_leoHighlightsGetAttrib%28anchor%2C%27leohighlights_reject%27%29%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%09leoHighlightsShowPopup%28anchorId%2C0%29%3B%0A%20%20%20%09return%20false%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22leoHighlightsHandleHover%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%09%0A%7D%0A%0A/**%0A%20*%20This%20will%20handle%20the%20mouse%20over%20setup%20timers%20for%20the%20appropriate%20timers%0A%20*%20%0A%20*%20@param%20id%0A%20*%20@return%0A%20*/%0Afunction%20leoHighlightsHandleMouseOver%28id%29%0A%7B%0A%09try%0A%09%7B%0A%09%20%20%20if%28_leoHighlightsIsFrame%28%29%29%0A%09%20%20%20%20%20%20return%3B%0A%09%20%20%20%0A%09%09var%20anchor%3D_leoHighlightsFindElementById%28id%29%3B%09%09%0A%0A%09%09/*%20Clear%20the%20end%20timer%20if%20required%20*/%0A%09%09if%28anchor.endTimer%29%0A%09%09%09clearTimeout%28anchor.endTimer%29%3B%0A%09%09anchor.endTimer%3Dnull%3B%0A%09%09%0A%09%09anchor.style.background%3DLEO_HIGHLIGHTS_BACKGROUND_STYLE_HOVER%3B%0A%09%09%0A%09%09/*%20The%20element%20is%20already%20showing%20we%20are%20done%20*/%0A%09%09if%28anchor.shown%29%0A%09%09%09return%3B%0A%09%09%0A%09%09/*%20Setup%20the%20start%20timer%20if%20required%20*/%0A%09%09anchor.startTimer%3DsetTimeout%28function%28%29%7B%0A%09%09%09leoHighlightsHandleHover%28anchor.id%29%3B%0A%09%09%09anchor.hover%3Dtrue%3B%0A%09%09%09%7D%2C%0A%09%09%09LEO_HIGHLIGHTS_SHOW_DELAY_MS%29%3B%0A%09%7D%0A%09catch%28e%29%0A%09%7B%0A%09%09_leoHighlightsReportExeception%28%22leoHighlightsHandleMouseOver%28%29%22%2Ce%29%3B%20%20%20%09%0A%09%7D%0A%7D%0A%0A/**%0A%20*%20This%20will%20handle%20the%20mouse%20over%20setup%20timers%20for%20the%20appropriate%20timers%0A%20*%20%0A%20*%20@param%20id%0A%20*%20@return%0A%20*/%0Afunction%20leoHighlightsHandleMouseOut%28id%29%0A%7B%0A%09try%0A%09%7B%09%0A%09%09var%20anchor%3D_leoHighlightsFindElementById%28id%29%3B%0A%09%09%0A%09%09/*%20Clear%20the%20start%20timer%20if%20required%20*/%0A%09%09if%28anchor.startTimer%29%0A%09%09%09clearTimeout%28anchor.startTimer%29%3B%0A%09%09anchor.startTimer%3Dnull%3B%0A%09%09%0A%09%09anchor.style.background%3DLEO_HIGHLIGHTS_BACKGROUND_STYLE_DEFAULT%3B%0A%09%09if%28%21anchor.shown||%21anchor.hover%29%0A%09%09%09return%3B%0A%09%09%0A%09%09/*%20Setup%20the%20start%20timer%20if%20required%20*/%0A%09%09anchor.endTimer%3DsetTimeout%28function%28%29%7B%0A%09%09%09leoHighlightsHideElem%28LEO_HIGHLIGHTS_IFRAME_DIV_ID%29%3B%0A%09%09%09anchor.shown%3Dfalse%3B%0A%09%09%09_leoHighlightsPrevElem%3Dnull%3B%0A%09%09%09%7D%2CLEO_HIGHLIGHTS_HIDE_DELAY_MS%29%3B%0A%09%7D%0A%09catch%28e%29%0A%09%7B%0A%09%09_leoHighlightsReportExeception%28%22leoHighlightsHandleMouseOut%28%29%22%2Ce%29%3B%20%20%20%09%0A%09%7D%0A%7D%0A%0A/**%0A%20*%20This%20handles%20the%20mouse%20movement%20into%20the%20currently%20opened%20window.%0A%20*%20Just%20clear%20the%20close%20timer%0A%20*%20%0A%20*%20@return%0A%20*/%0Afunction%20leoHighlightsHandleIFrameMouseOver%28%29%0A%7B%0A%09try%0A%09%7B%0A%09%09if%28_leoHighlightsPrevElem%26%26_leoHighlightsPrevElem.endTimer%29%0A%09%09%09clearTimeout%28_leoHighlightsPrevElem.endTimer%29%3B%0A%09%7D%0A%09catch%28e%29%0A%09%7B%0A%09%09_leoHighlightsReportExeception%28%22leoHighlightsHandleIFrameMouseOver%28%29%22%2Ce%29%3B%20%20%20%09%0A%09%7D%0A%7D%0A%0A/**%0A%20*%20This%20handles%20the%20mouse%20movement%20into%20the%20currently%20opened%20window.%0A%20*%20Just%20clear%20the%20close%20timer%0A%20*%20%0A%20*%20@param%20id%0A%20*%20@return%0A%20*/%0Afunction%20leoHighlightsHandleIFrameMouseOut%28%29%0A%7B%0A%09try%0A%09%7B%0A%09%09if%28_leoHighlightsPrevElem%29%0A%09%09%09leoHighlightsHandleMouseOut%28_leoHighlightsPrevElem.id%29%3B%0A%09%7D%0A%09catch%28e%29%0A%09%7B%0A%09%09_leoHighlightsReportExeception%28%22leoHighlightsHandleIFrameMouseOut%28%29%22%2Ce%29%3B%20%20%20%09%0A%09%7D%0A%7D%0A/**%0A%20*%20This%20is%20a%20method%20is%20used%20to%20make%20the%20javascript%20within%20IE%20runnable%0A%20*/%0Avar%20leoHighlightsRanUpdateDivs%3Dfalse%3B%0Afunction%20leoHighlightsUpdateDivs%28%29%0A%7B%0A%09try%0A%09%7B%0A%09%09/*%20Check%20if%20this%20is%20an%20IE%20browser%20and%20if%20divs%20have%20been%20updated%20already%20*/%0A%09%09if%28document.all%26%26%21leoHighlightsRanUpdateDivs%26%26%21_leoHighlightsIsFrame%28%29%29%0A%09%09%7B%0A%09%09%09leoHighlightsRanUpdateDivs%3Dtrue%3B%20//%20Set%20early%20to%20prevent%20running%20twice%0A%09%09%09for%28var%20i%3D0%3Bi%3CLEO_HIGHLIGHTS_MAX_HIGHLIGHTS%3Bi++%29%0A%09%09%09%7B%0A%09%09%09%09var%20id%3D%22leoHighlights_Underline_%22+i%3B%0A%09%09%09%09var%20elem%3D_leoHighlightsFindElementById%28id%29%3B%0A%09%09%09%09if%28elem%3D%3Dnull%29%0A%09%09%09%09%09break%3B%0A%09%09%09%09%0A%09%09%09%09if%28%21elem.leoChanged%29%0A%09%09%09%09%7B%0A%09%09%09%09%09elem.leoChanged%3Dtrue%3B%0A%09%09%09%09%0A%09%09%09%09%09/*%20This%20will%20make%20javaScript%20runnable%20*/%09%09%09%09%0A%09%09%09%09%09elem.outerHTML%3Delem.outerHTML%3B%0A%09%09%09%09%7D%0A%09%09%09%7D%0A%09%09%7D%0A%09%7D%0A%09catch%28e%29%0A%09%7B%0A%09%09_leoHighlightsReportExeception%28%22leoHighlightsUpdateDivs%28%29%22%2Ce%29%3B%20%20%20%09%0A%09%7D%0A%7D%0A%0Aif%28document.all%29%0A%09setTimeout%28leoHighlightsUpdateDivs%2C200%29%3B%0A%0A%0A/**%0A%20*%20This%20is%20used%20to%20report%20events%20to%20the%20plugin%0A%20*%20@param%20key%0A%20*%20@param%20domain%0A%20*%20@param%20keywords%0A%20*%20@param%20vendorId%0A%20*%20@param%20accept%0A%20*%20@param%20reject%0A%20*%20@return%0A%20*/%0Afunction%20leoHighlightsReportEvent%28key%2C%20domain%2Ckeywords%2CvendorId%2Caccept%2Creject%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20var%20gwObj%20%3D%20new%20Gateway%28%29%3B%0A%20%20%20%20%20%20gwObj.addParam%28%22key%22%2Ckey%29%3B%0A%20%20%20%20%20%20if%28domain%21%3Dnull%29%0A%20%20%20%20%20%20%20%20%20gwObj.addParam%28%22domain%22%2Cdomain%29%3B%0A%20%20%20%20%20%20if%28keywords%21%3Dnull%29%0A%20%20%20%20%20%20%20%20%20gwObj.addParam%28%22keywords%22%2Ckeywords%29%3B%0A%20%20%20%20%20%20if%28vendorId%21%3Dnull%29%0A%20%20%20%20%20%20%20%20%20gwObj.addParam%28%22vendorId%22%2CvendorId%29%3B%0A%20%20%20%20%20%20if%28accept%21%3Dnull%29%0A%20%20%20%20%20%20%20%20%20gwObj.addParam%28%22accept%22%2Caccept%29%3B%0A%20%20%20%20%20%20if%28reject%21%3Dnull%29%0A%20%20%20%20%20%20%20%20%20gwObj.addParam%28%22reject%22%2Creject%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20gwObj.callName%28%22LeoHighlightsEvent%22%29%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHighlights%28%29%22%2Ce%29%3B%20%20%20%20%20%0A%20%20%20%7D%0A%7D%0A%0A/**%0A%20*%20This%20will%20expand%20or%20collapse%20the%20window%20base%20on%20it%20prior%20state%0A%20*%20%0A%20*%20@return%0A%20*/%0Afunction%20leoHighlightsToggleSize%28clickId%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%20%20%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22leoHighlightsToggleSize%28%29%20%22+_leoHighlightsPrevElem%29%3B%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20/*%20Get%20the%20hover%20flag%20and%20change%20the%20status%20*/%0A%20%20%20%20%20%20var%20size%3D_leoHighlightsPrevElem.hover?1%3A0%3B%0A%20%20%20%20%20%20_leoHighlightsSetBottomSize%28size%2CclickId%29%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHighlightsToggleSize%28%29%22%2Ce%29%3B%20%20%20%20%20%0A%20%20%20%7D%0A%7D%0A%0A/**%0A%20*%20Call%20into%20the%20kvm%20that%20will%20then%20do%20a%20callback%20into%20the%20top%20window%0A%20*%20The%20top%20window%20will%20then%20call%20leoH%0A%20*%20%0A%20*%20@return%0A%20*/%0Afunction%20leoHighlightsSetSecondaryWindowUrl%28url%2C%20customerId%2C%20phraseId%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%20%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22leoHighlightsSetSecondaryWindowUrl%28%29%20%22+url%29%3B%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20var%20gwObj%20%3D%20new%20Gateway%28%29%3B%0A%20%20%20%20%20%20gwObj.addParam%28%22url%22%2C%20url%29%3B%0A%20%20%20%20%20%20gwObj.addParam%28%22phraseId%22%2C%20phraseId%29%3B%0A%20%20%20%20%20%20gwObj.addParam%28%22customerId%22%2C%20customerId%29%3B%0A%20%20%20%20%20%20gwObj.callName%28%22LeoHighlightsSetSecondaryWindowUrl%22%29%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHighlightsSetSecondaryWindowUrl%28%29%22%2Ce%29%3B%20%20%20%20%20%0A%20%20%20%7D%0A%7D%0A%0A/**%0A%20*%20Call%20into%20the%20kvm%20that%20will%20then%20do%20a%20callback%20into%20the%20top%20window%0A%20*%20The%20top%20window%20will%20then%20call%20leoH%0A%20*%20%0A%20*%20@return%0A%20*/%0Afunction%20leoHighlightsSetSecondaryWindowUrlCallback%28url%2C%20customerId%2C%20phraseId%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%20%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22leoHighlightsSetSecondaryWindowUrlCallback%28%29%20%22+url%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20/*%20Clear%20the%20hover%20flag%2C%20if%20the%20user%20shows%20this%20at%20full%20size%20*/%0A%20%20%20%20%20%20var%20size%3D_leoHighlightsPrevElem.hover?0%3A1%3B%20%20%20%20%20%20%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22leoHighlightsSetSecondaryWindowUrlCallback%28%29%20%22+_leoHighlightsPrevElem+%22%20--%20%22+_leoHighlightsPrevElem.hover%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20/*%20Get%20the%20elements%20*/%0A%20%20%20%20%20%20var%20iFrameBottom%3D_leoHighlightsFindElementById%28LEO_HIGHLIGHTS_IFRAME_BOTTOM_ID%29%3B%0A%20%20%20%20%20%20leoHighlightsUpdateUrl%28iFrameBottom%2Csize%2Cnull%2Curl%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22leoHighlightsSetSecondaryWindowUrlCallback%28%29%20%22+url%29%3B%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHighlightsSetSecondaryWindowUrlCallback%28%29%22%2Ce%29%3B%20%20%20%20%20%0A%20%20%20%7D%0A%7D%0A%0A/**%0A%20*%20This%20will%20set%20the%20text%20to%20the%20Top%20%0A%20*%20%0A%20*%20@param%20txt%0A%20*%20@return%0A%20*/%0Afunction%20leoHighlightsSetExpandTxt%28txt%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%20%0A%20%20%20%20%20%20var%20topIFrame%20%3D%20_leoHighlightsFindElementById%28LEO_HIGHLIGHTS_IFRAME_TOP_ID%29%3B%0A%20%20%20%20%20%20if%28topIFrame%3D%3Dnull%29%0A%20%20%20%20%20%20%20%20%20return%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20/*%20Get%20the%20current%20url%20*/%0A%20%20%20%20%20%20var%20url%3DtopIFrame.src%3B%20%20%20%20%20%20%0A%20%20%20%20%20%20if%28url%3D%3Dnull%29%0A%20%20%20%20%20%20%20%20%20return%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20/*%20Extract%20the%20previous%20hash%20if%20present%20*/%0A%20%20%20%20%20%20var%20idx%3D-1%3B%20%20%20%20%20%20%0A%20%20%20%20%20%20if%28%28idx%3Durl.indexOf%28%27%23%27%29%29%3E0%29%0A%20%20%20%20%20%20%20%20%20url%3Durl.substring%280%2Cidx%29%3B%0A%0A%20%20%20%20%20%20/*%20Append%20the%20text%20to%20the%20end%20*/%0A%20%20%20%20%20%20url+%3D%22%23%22+encodeURI%28txt%29%3B%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20/*%20Set%20the%20iframe%20with%20the%20new%20url%20that%20contains%20the%20hash%20tag%20*/%0A%20%20%20%20%20%20topIFrame.src%3Durl%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHighlightsSetExpandTxt%28%29%22%2Ce%29%3B%20%20%20%20%20%0A%20%20%20%7D%0A%7D%0A%0A/*----------------------------------------------------------------------*/%0A/*%20Methods%20provided%20to%20the%20highlight%20providers...%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20*/%0A/*----------------------------------------------------------------------*/%0A%0A/**%0A%20*%20This%20will%20set%20the%20expand%20text%20for%20the%20Top%20window%0A%20*/%0Afunction%20leoHL_SetExpandTxt%28txt%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsDebugLog%28%22leoHL_SetExpandTxt%28%29%20%22+txt%29%3B%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20_leoHighlightsSimpleGwCallBack%28%22LeoHighlightsSetExpandTxt%22%2C%22expandTxt%22%2Ctxt%29%3B%20%20%20%20%20%20%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHL_SetExpandTxt%28%29%22%2Ce%29%3B%20%20%20%20%0A%20%20%20%7D%0A%7D%0A%0A/**%0A%20*%20This%20will%20redirect%20the%20top%20window%20to%20the%20passed%20in%20url%0A%20*%20%0A%20*%20@param%20url%0A%20*%20@param%20parentId%0A%20*%20@return%0A%20*/%0Afunction%20leoHL_RedirectTop%28url%2CparentId%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%20%0A%20%20%20%20%20%20try%7B%0A%20%20%20%20%20%20%20%20%20var%20domain%3D_leoHighlightsGetUrlArg%28window.document.URL%2C%22domain%22%29%0A%20%20%20%20%20%20%20%20%20var%20keywords%3D_leoHighlightsGetUrlArg%28window.document.URL%2C%22keywords%22%29%0A%20%20%20%20%20%20%20%20%20var%20vendorId%3D_leoHighlightsGetUrlArg%28window.document.URL%2C%22vendorId%22%29%0A%20%20%20%20%20%20leoHighlightsReportEvent%28%22clickthrough%22%2C%20domain%2Ckeywords%2C%20vendorId%29%3B%0A%20%20%20%20%20%20%7Dcatch%28e%29%7B%0A%20%20%20%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHL_RedirectTop%28%29%22%2Ce%29%3B%20%20%20%20%0A%20%20%20%20%20%20%7D%0A%20%20%09%09%0A%20%20%20%09_leoHighlightsRedirectTop%28url%29%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22leoHL_RedirectTop%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%0A%7D%0A%0A/**%0A%20*%20This%20will%20redirect%20the%20top%20window%20to%20the%20passed%20in%20url%0A%20*%20%0A%20*%20@param%20url%0A%20*%20@param%20parentId%0A%20*%20@return%0A%20*/%0Afunction%20LeoHL_RedirectTop%28url%2CparentId%29%0A%7B%0A%20%20%20leoHL_RedirectTop%28url%2CparentId%29%3B%0A%7D%0A%0A/**%0A%20*%20This%20will%20redirect%20the%20top%20window%20to%20the%20passed%20in%20url%0A%20*%20%0A%20*%20@param%20url%0A%20*%20@param%20parentId%0A%20*%20@return%0A%20*/%0Afunction%20leoHL_RedirectTopAd%28url%2CparentId%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%20%0A%20%20%20%20%20%20try%7B%0A%20%20%20%20%20%20%20%20%20var%20domain%3D_leoHighlightsGetUrlArg%28window.document.URL%2C%22domain%22%29%0A%20%20%20%20%20%20%20%20%20var%20keywords%3D_leoHighlightsGetUrlArg%28window.document.URL%2C%22keywords%22%29%0A%20%20%20%20%20%20%20%20%20var%20vendorId%3D_leoHighlightsGetUrlArg%28window.document.URL%2C%22vendorId%22%29%0A%20%20%20%20%20%20leoHighlightsReportEvent%28%22advertisement.click%22%2C%20domain%2Ckeywords%2C%20vendorId%29%3B%0A%20%20%20%20%20%20%7Dcatch%28e%29%7B%0A%20%20%20%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHL_RedirectTopAd%28%29%22%2Ce%29%3B%20%20%20%20%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%0A%20%20%20%20%20%20_leoHighlightsRedirectTop%28url%29%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHL_RedirectTopAd%28%29%22%2Ce%29%3B%20%20%20%20%0A%20%20%20%7D%0A%7D%0A%0A%0A/**%0A%20*%20This%20will%20set%20the%20size%20of%20the%20iframe%0A%20*%20%0A%20*%20@param%20url%0A%20*%20@param%20parentId%0A%20*%20%0A%20*%20@return%0A%20*/%0Afunction%20leoHl_setSize%28size%2Curl%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%09/*%20Get%20the%20clickId%20*/%0A%20%20%20%09var%20clickId%3D_leoHighlightsGetUrlArg%28%20url%2C%22clickId%22%29%0A%20%20%20%09%0A%20%20%20%20%20%20var%20gwObj%20%3D%20new%20Gateway%28%29%3B%0A%20%20%20%20%20%20gwObj.addParam%28%22size%22%2Csize%29%3B%0A%20%20%20%20%20%20if%28clickId%29%0A%20%20%20%20%20%20%20%20%20gwObj.addParam%28%22clickId%22%2CclickId+%22_blah%22%29%3B%0A%20%20%20%20%20%20gwObj.callName%28%22LeoHighlightsSetSize%22%29%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%09_leoHighlightsReportExeception%28%22leoHl_setSize%28%29%22%2Ce%29%3B%20%20%20%09%0A%20%20%20%7D%0A%7D%0A%0A/**%0A%20*%20This%20will%20toggle%20the%20size%20of%20the%20window%0A%20*%20%0A%20*%20@return%0A%20*/%0Afunction%20leoHl_ToggleSize%28%29%0A%7B%0A%20%20%20try%0A%20%20%20%7B%0A%20%20%20%20%20%20var%20gwObj%20%3D%20new%20Gateway%28%29%3B%0A%20%20%20%20%20%20gwObj.callName%28%22LeoHighlightsToggleSize%22%29%3B%0A%20%20%20%7D%0A%20%20%20catch%28e%29%0A%20%20%20%7B%0A%20%20%20%20%20%20_leoHighlightsReportExeception%28%22leoHl_ToggleSize%28%29%22%2Ce%29%3B%20%20%20%20%20%0A%20%20%20%7D%0A%7D%0A%0A"); </script>
Update:
I have the A-arm design done and fixture laid out. All the materials have been ordered (Hiem joints tubing new notcher shocks...) the fixture will be ready by the end of this week.
I will post some new pictures later this afternoon but until then here is a screen shot of some of my changes.
Cheers,
Brett
Just found this build thread. Looks good. Lots of hard work ahead of you and already behind you. I'll be following this build. Thanks for sharing !
Wait till you guys see this in person next year at the big rides. It's really amazing. Never seen a UTV built like this. Agressive looks with unbelievable suspension. Wait and see :)
:cool:
Update:
Not a lot to show as far as fabrication goes I have been doing a lot of design work on the A-arms and buying/ building tools...
Here is a pic of the A-arm design in Solid Works I will bend and weld them this weekend. I cant wait to see this thing sitting on its wheels again!
Oh and some pic's of my A-arm fixture I built it out of some aluminum extrusion and a slide so it can be adjusted for sweep and length.
Cheers,
Brett
KING OF THE HAMMERS IS GOING TO GET BIGGER AND BETTER!
THIS IS WHAT HAMMER TOWN IS ABOUT!!
Brett,
That looks good. nice jig you made there. I'm looking forward to seeing more.
Thank you Darryl I am ready to see things come together too!! :D
man this build looks great im even getting motivated to build a KOH rig
I know what you mean it was Jon's (crowdog) build that did it for me!
I cant wait to experience this awesome event!! Just to run in the KOH is going to be amazing.
Here are some fun screen captures... I need to weld something LOL
OK those solid works pics are way to much fun. I highly recomend clicking through them fast. It's like an old fashion cartoon. You can really see how much travel this Mean Machine has!
Lets start bending and welding tonight!
Jonas - you home yet?
