CT Racing Maverick Build
I didnt. The Gorilla outers are holding up great so I didn't feel the need to press forward with it when there was already something on the market that worked well.
Now we're working on steering racks.
Here's a little preview of the steering rack.
Did you decide on what to do with the toe links and brake calipers? Who is making your new drive shaft? I need to get a couple of more made up, and I wasn't happy with the last guy I used. Now, you'll be able to dyno it when your done and see how much power you gain at the rear wheels. Let me know! Thanks.
FYI, you may need a custom brake line to go from the master cyl. to the rear "T". Mine was barely long enough, and you extended the rear wheelbase by 6", correct? I moved mine 4 1/2", but I did widen it by 11". You may want to order in advance if you do.
We leave for the expo in 2 days so I left the radius rods in the front and flopped the spindles and calipers for the time being. The high clearance lower arms make getting the radius rods in there a complete whore. When I get back from the expo I'll strip it back down and address those issues in full.
Drive shaft wise I have a brand new one here as I need to get all my measurements nailed down for production. As of now I cut my stock one in the lathe, got it as close as I could, timed the U joints and burned it in. That's something that will get properly addressed when I get back as well.
