Kawasaki Teryx LT Compendium
So since the other thread started by Dez-Racer regarding Teryx LT Suspension kits kind of got off track I have decided to move a couple of the key posts over here and start a fresh thread dedicated to this subject and based around the specs and facts of the kits.
I think this is a good opportunity for ALL companies manufacturing Long Travel Suspensions to come onto the Underground and tell us a little about their kit. Feel free to include a link to their site and any pictures are more than welcome!!!
I think in these discussions we should begin to start talking about details and not just general observations or opinions. so we will start here with BYC or if anyone else wants to throw in how their kit is deisgnd and what makes it the best?
Some things to put in:
Arm Construction: Boxed - Tube - is it Chromoly or?
Components: Uniball Both Upper Lower - Ball Joints Upper Lower - Uniball/Ball Joint combo
Shock Towers: Front and Back - Just Front - Just Back - None
Width: +3 - +5 - +6
Length: +2 Forward - +2 Back - Both - None
Shocks: ANY - Fox - Walkers - King - Elka - Other
Suspension Travel: Front________ - Rear________
Include details you feel are important such as if the shocks provided are pre valved for the kit, if the kit carries a warranty, manufacturer of reccomended axles/cv's, and anything else you feel important for a consumer to know.
Did I leave anything out? Copy and paste the above listing and highlight your answers. This info is what matters who runs what doesnt mean anything IMO, its the old Ford vs. Chevy argument and I think Chevy Sucks! LOL
COGNITO Teryx Kit
COGNITO
Joey the cognito kit is not quite ready for release yet. Justin is planning a day with fox to go out and get the shocks dialed in before its ready to hit the market....We ran the sheeet out of it @ dumont T day and it works great but it needs a little valving yet....There will also be a shock tower model available using the new Fox position sensitive shocks:D hopefully it was alright for me to let the cat out of the bag
Some specs on the Cognito kit
Arm Construction: Boxed - Tube - Boxed load arm/ tube non load arm
Components: Uniball Upper and lower
Shock Towers: Optional with Fox Position sensitive shocks
Width: +5
Length: +0 Forward - +1 Back
Shocks: - Fox - Standard/rc-2/position sensitive
Susepension Travel: Front___16"_____ - Rear___16"_____ dont quote me on travel
from the other thread..........
Re: COGNITO Teryx Kit
LONG TRAVEL INDUSTRIES
Long Travel Industries
Arm Construction: Engineered in Solidworks CnC lasered Boxed Chromoly ....Lighter than most tube arm kits on the market
Components: FK 7/8" teflon coated spherical bearings Both Upper Lower with heat treated 17-4 S.S tapered pins
Shock Towers: None
Width: +5
Length: 1.78" Of total wheel base added
Shocks: Standard with king 2.0 but will work with walker, fox and most other 2" coilovers
Susepension Travel: Front 14" - Rear 14"
Here are the details on our kits:
MTS +3 Kit details:
Arm Construction: Tube, certified aircraft 4130 tube, CNC laser cut 4130 tabs and gussets, TIG welded
Components: Ball Joints Upper Lower
Shock Towers: None
Width: +3
Shocks: uses stock length, Tuned Foxes and Elkas recommeneded and normally sold with kit
Suspension Travel: Front__11.5______ - Rear___12.5_____
Kit comes with lifetime warranty on a-arms and axle shafts, easy adjust caster, and powdercoated finishes, complete with instructions and all hardware needed for installation.
XTR +5 Kit details:
Shock Towers: None
Width: +5
Shocks: uses long travel shocks, Tuned Foxes and Elkas recommeneded and normally sold with kit
Suspension Travel: Front__14.8______ - Rear___16.25_____
XTR-F +5 Kit details:
Shock Towers: Front and Rear (rear clears 12 gal fuel cell, front requires cutting of hood)
Width: +5
Shocks: uses tuned Fox position sensitive shocks with dual rate springs (8.5" travel front, 10" travel rear)
Suspension Travel: Front__15.5______ - Rear___15.5_____
Kit comes with lifetime warranty on a-arms and axle shafts, easy adjust caster, and powdercoated finishes, complete with instructions and all hardware needed for installation. The XTR-F kit is meant for racing and has ideal shock geometery for serious use and abuse with extra resistance to bottoming out with the position sensitive shocks. It is also compatable with Gear One centerboard hub kit with the use of limit straps on rear end.
Kit is also upgradable from XTR to XTR-F with purchase of shock towers and shocks.
All of our kits are designed 100% in CAD, along with the welding fixtures to ensure perfect geometery and quality, and have been for many years. Then each kit is tested and tuned with the shocks for a variety of terrian. Most kits have shocks that are dialed for Dunes, Desert, MX Racing, etc, so be sure to specify upon ordering.
Thanks!
www.lsracing.com
MAGNUM OFFROAD
Kawasaki Teryx +6 Suspension System
Arm Construction: 4130 Chromoly Tube Construction
Components: Upper FK Rod End For Camber Adjustment / Lower FK Teflon Lined Spherical Bearing
Width: +6 Length: +0
Shocks: Fox Racing 2.0 Shocks w/ Remote Reservoir (Adjusters Also Available)
Suspension Travel: Front 16" - Rear 15"
Kit comes complete with everything needed for installation including Summers Brothers 4340 extended axles and 4130 tie rod extensions. The system also features a Limited Lifetime Warranty that covers any defects in materials or craftsmanship.
Feel free to contact us with any questions!
Any with adjustable castor or adjustable camber? How about rear tow? ..... anyone with the ability to adjust the rear tow? :D
MAGNUM OFFROAD
I LIKE GREEN!!!!:D:D:D
HRT corrects this to Zero.
NICE ..... now your talking. I think this is the first thing i would do if i was designing a LT kit. I would like to try to run it a few ways. Stock then with about 1/4 toe in and then ZERO toe in.
yeah ... but the shocks are mounted to the upper a-arms on most kits. I woudl not like to run inner hiems on the a-arm that the shock mounts to.
The teryx has rear toe stock .......
The cognito rhino kit has all heim pick up points....With the added cost its not doing real well....Most guys aren't looking to pay for those kinds of options.
The cognito Teryx kit is toed in about 1/2 degree on each side.
I am not a big fan of rod ended heims ...... i think it has about 1 inch or total toe stock? I will have a new kit on my 2010 that will have adjustable camber and adjustable toe WITHOUT heims. I had his kit on my rhino and it was pretty SIK. Just seeing what other options are out there before i pull the trigger.
COGNITO
I stand corrected on the travel...some more info
Travel front and rear is 14".
Material is all mild steel, and has no problem taking the abuse, so i steered clear of the chromoly.
Price with summers bros 300M rear shafts and 4340 front shafts, and
FOX piggyback non adjustable shocks is $3940.00
FOX piggyback RC2 adjustable shocks is $4540.00
FOX piggyback position sensitive shock with front and rear shock towers $not yet
Toe in on the rear is not a bad thing. Most independent rear suspensions are designed this way. The toe in helps with cornering and tracking straight. Negative camber is also not a bad thing. The camber can be set at -3degrees so when rail a corner the tire corrcts to 0 degrees putting the full contact patch on the ground. Mafia sets up their Rhino arms like this.
I am notsaying it is bad ..... what i am saying is WHO has tested it both ways? or with less toe? or maybe more toe? I am pretty sure most people building kits have not tested this. So it woudl be cool to hear from someone that did test it or someone that makes and adjustable kit. Thats all i am saying .....BEST YOU KNOW IS THE BEST YOU HAVE BEEN IN.
Chad Mittag did some testing with and without. There is alot of suspension geometry books that discuss this. I will look for some more info on this tomorrow.
Who is that and what kit for the teryx does he build?
i am sure there are opinions for everything, but i like to test them and see what i find to work. If you just follow what everyone else has you will be doing just that .......
