JaggedX RZR XP900 BITD race car build thread...
A little heavier than we hoped but not bad considering the tire & wheel combo being quite a bit more. We are hovering around 1700 with spare & about 10 gal fuel.
Not to bad at all! Yea those tires and wheels look to add some weight for sure. That car must be some fun times driving. Great job again on this build.
1700lbs holy crap:eek: my single seat 1600 car is 1479lbs dry wow i need to weigh the gator
Awesome build, had a couple of questions regarding bitd builds. It says you can make the wheel base 8" longer, does that mean you can move the location of the motor.
No, the motor must remain in stock location and the OEM frame rails must remain stock. Typically, you lengthen the wheelbase by using modified a-arms or J-arms..
You can see the J-arms on the rear of this car. With 1+ inch forward placement on the front a-arms and 5+ inches back on the rear j-arms, the wheelbase is lengthened almost 7 inches..
Kris, if you go to the racing section of the forums, Joey has posted a majority of the rules regarding BITD and many others...
Welcome to the best damn forum there is for UTV's/Side By Sides...
