i attest to the ITP ultracross, no flats at Silver State, none at Baja 500, none at V2R (the 350 miles that we did), none at BWDC.
We had 2 flats at the Mint 400, dusty as heck and hit a boulder for the first flat, the second flat i was surprised at. But 2 flats for about 1400 miles is outstanding.
Method race wheels, no failures all season. They have a 4/3 offset and a 5/2 offset available.
If you PM me your email address, I'll send over some pics. I'd rather not do it here.I'd say you are ahead of the curve on avoiding flats! I'm thinking ITP is the tire to run. I would have no issues running Method wheels. Talked to the rep some at V2R. Real cool guy.
Years ago I remember reading about some time trial team in Japan that ran cast wheels because they were getting too much flex with forged wheels. The casting process makes it easier to forms ribs and such on the backside of the wheel where no one ever looks. While cast wheels are typically heavier than a forged one, the extra freedom in design without having to do secondary machining to produce details like strengthening ribs, makes one wonder if a good designed cast wheel can't out perform other options. I have never looked at the backside of an OMF but if it is flat, they are sacrificing strength by not increasing the center thickness then machining lightening pockets. Reid, I would be interested in what is happening to your centers?
A lot of us guys thay rum tire balls run them with no air in the tire, just in the balls so a bead lock is a most. I really like the OMF, it's one of the best if not the best for sure but I run the Methods and I'm really happen with them. The Avid Mav that I race BITD with runs them and during V2R I shredded a tire and the rim was fine. They're 15" rims with 30" mongrels. I personally wouldn't run an LT tire.
Yeah, I'm learning to take it! Just didn't want the ugly images going out over the airwaves. I'm trying to consider our sponsors when sharing info publicly, which I dislike doing. I am morphing into a "kinder, gentler" version of the Badassmav, if there ever could be such a thing.Says the full disclosure king!! Bwahaha....Just Rib'n ya reid!
That's what it looks like when the Cognito boys build a chassis, except for the fact that it is not a time lapse! Those dudes whip out a rolling chassis like its a front bumper. Start, whoosh,.......... done!
Yeah its not my car. I come out to help/drive in BITD. I'm in NC, my car out here has them.Interesting to see a tube used in a cast beadlock wheel. Not sure how you are using tire blocks or balls with a tube, or did I miss understand your comments about V2R?
Well,what do you know. Perhaps Nikal may have a "fighting dog" after all!Oh, did I forget to tell you that you are on pit duty? Why else would I wrangle someone onto the team?!!! haha
Scrub radius would be modified just by the nature of changing wheels and using a 30" tire. I would consider the factory scrub radius to be very satisfactory, either stock or with a 30" tire and the right wheel offset. The closer to zero the better but not the end of the world if it is within say 10% of the tire.
Reid, does yours have an excessive amount? Just wondering why you need steering stabilizers on you car. I would also be interested in someones argument why a larger moment of polar inertia would be desired. Care to make a case for it? I can think of a few arguments but it would all be playing devils advocate.
Anti-dive: two thumbs way up for polaris. For the high center of gravity and the long travel these things have its a good thing. I have never put in any anti dive in the stiffly sprung road based cars I have worked on. they were extremely low with very little camber gain in bump so the front tires were still upright if the front dove the little travel it had.
They are not. At a glance, the top arm pivot axis will intersect the bottom one just past the rear of the car, increasing the caster as the suspension bumps.I believe the steering stabalizers are to save the rack. The electric P/S doesn't give and is hard on them.
Hey Reid, are the front a arm pick up points on the po po not parallel to each other?
When I modified our spindles, I adjusted the lower ball joint position to add a bit more scrub radius than stock. I want to say that it is about 1 1/2" - 2" in its current configuration. I am a fan of the scrub radius because it gives the driver more feedback through the steering wheel. I designed the second truck I ever built with 0 scrub radius, and only 1-2 degrees positive caster. The result was that the steering gave very little feedback, and made it more difficult to drive hard in the corners. It wasn't too good at returning to center neither.Scrub radius would be modified just by the nature of changing wheels and using a 30" tire. I would consider the factory scrub radius to be very satisfactory, either stock or with a 30" tire and the right wheel offset. The closer to zero the better but not the end of the world if it is within say 10% of the tire.
About the PMOI, I would like to build a vehicle without restrictions so I could play with it a bit. I think that drivers with limited experience would adjust to a car much faster if the moment of inertia was high. The car will not be as responsive as it would if it had a low PMOI.
