New guy, needs some help.
Undertaker
I have a 09 RZR that is stock. Thanks to RZRS Edge Bill, I took out the spacer in the primary and that's it. My question is what should I do next, performance or handling wise? I live just north of Pittsburgh, PA so we don't do a lot of desert riding! Mostly trails and tight woods. Should I do the shocks, pipe or what? I would really appreciate some opinions.
Thanks everyone!
If you are just doing woods then I would do performance unless you don't like the way your suspension Handels then I would go with shocks
If you put an exhaust on it you should run with the UMP air filter and a fuel controller also, you will notice a big difference after that.
Get a full exhaust system and you will gain some HP! Long TRAVEL is the way to go!! What suspension are you running?
I am running the stock suspension. Should I go with the Walker Evans, Fox or Elka? I would like to keep the stock width because of the tight trails that we ride. Maybe some wheel spacers?
What do you guys think about the Bikeman exhaust system. I have read a lot of good reviews..................?
for stock replacement i would recommend elkas, and some spacers will help with the stability if you dont want to go with a long travel
Unfortunately there is just not much cheap power avaliable for the RZR. I have the Muzzy exhaust, dyna ignition & fuel controller, UMP intake, a couple clutch "kits", etc. & I am just a hair faster then stock. The only mod that I did not test before/after was the exhaust. Other then that with over 200 recorded 450' test/modify runs I am about 3 tenths of a second faster in 450'.
Elka is the way to go we race an S with stock geometry and our elkas have been flawless, as for the performance exhaust and a fuel controller is the best bang for the buck, however there are complete kits out there that will get you to 70 ,mph and quick:cool: though will set you back few grand, it all about your budget.
Rhino Parts and Performance will take good care of you!! Although I am partial to Walker Evans the Elkas are some nice units!
WALKER EVANS!!!!!!
Daniel F
