Yamaha Need help with Comet clutch removal!
JLeeper
J-Leep - UTVUnderground Approved
I understand the bolt and rod trick to back the clutch off the crank. I just can't find the proper thread size for the bolt. This is driving me CRAZY!:mad: It appears to be close to a 18 thread and between a 9/16 and 5/8 bolt size. McFadden hardware says it must be a 15mm that they don't have.
Any help ? Thanks.
Thanks for the help. Called Benchmark, they are checking size. If it doesn't work out I might need to buy it.
Any help ? Thanks.
where are you located????
Any help ? Thanks.
