Yamaha ?input on muzzys?
Heres some pics of the MUZZY installed
Hmmmmmm , I didnt gain any speed,Its quicker. Do you think its a JET issue?
Im still running the stock jet??It goes the same speed as the stocker w/ a leak. Tops out at 49mph somethings wrong,and thats on street with no cage or tailgate????Big moe's goes 53 mph on the street,Stock..
Running a Pro design foam filter with alum color.LID OFF
Im going to change the oil and throw the cage on and see what happens?
What jet?
I think your right JOE !!!!! How about the jetting would this cause an issue??
Anybody???????????
My mechanic says its the jetts ,your allowing more air so therefore you need more fuel.Im getting the valves adjusted and re-jetting.
Talked to MUZZY, they said put the lid back on the air filter box and you will see some gains.There's enough air already.Test when I get home.
They recomended buying a jet kit..
Put the lid on and tested it no different,Its at the mechanic and i need to know what jets to run?????????????HELPHELP?????????????Its getting a valve adjustment.
RACERS WHAT ARE YOU RUNNING FOR THE RHINO????What Jet????
TEST IN GLAMIS .....
BIG MOE stock pipe
against the family wagon MUZZY...
With nobbies.
The muzzy pulls low mid and top ends!!!!!!!! and WINS the race!!
By about 10-15 yrds in about 1/4 mile.
Get a Muzzy, it not only sounds good but the performance will show:)!!!
got my muzzys last week. put them on adjusted the fuel trim and took it out on the street before muzzys 56mph on flat ground 1 person = 200lbs after 61 mph two people = 400+ lbs hitting rev limiter at 8000 rpms
going up slight grade wow!!!!!!!!!!! 63 mph with 1 person fat a$$:cool:
