Yamaha ?input on muzzys?
FernandezRacing
Does anybody have any input on the muzzys exhaust system on a rhino 660?????????How do they sound and how much power gain.?????What jet is needed?????
Getting my muzzle tomorrow..I cant wait, The rhino goes 50 down a paved road now with out a muzzy exhaust.How fast is it going to go with the muzzy on and re- jetted ?????
If no replys,I will have some input this weekend...
What mods you have on your Rhino? I've been courious to hear the sound of a Muzzy. They sound awsome on a Teryx, but that is twin cyclinders.
The muzzy sounds good on the 660 and 700, and it is not crazy loud. It does not sound as good as the muzzy on the teryx. I have seen a 660 with a cdi, sheave, intake, jetting, and the muzzys run 63mph and 0-40 alittle over 5 secs. The jetting and the intake is worth around 2 hp, and the pipe worth around 4.5 hp. Before the pipe and intake it was almost 8 tenths slower 0-40. I would start with around a dj175 with the pipe. Not sure what other mods you have so thats just a guess, a air/fuel ratio gauge is a must for proper tunning. If you have alocal shop have them dyno tune it. I hope this helps.
good info RJV.....Dan, 50Tommy ran his rhino this last weekend for the first time with the Muzzys on and he LOVED them. Said they sound sick , look sick, and give more HP for sure!! You will not be dissapointed!!
Rjv thanks for the input, I have A foam filter with open lid,and CDI box right now, so for the most part its stock.Waiting on the muzzy to come in and i might have to get a muzzle for this rhino??????
Pretty sure the Muzzys setup for the Rhino uses the same cans as on the Teryx. They are longer than most other exhaust and quieter. Quality products come from Muzzys.
Just did mine on a 700. I gained about 8.5hp with a Muzzy and MSD. My first run (blue) was with stock exhaust, Rigid Intake, and a Dynatek. The second (red) was MSD, Muzzy, and Rigid Intake.
I'll be taking it out this weekend but I'm happy with the power results. Pulls a lot better than it did.
I that test was on a 700efi, so no jets. Did you get your exhaust yet?
Still waiting on 2 crush washers that go between the header and motor,on order at temecula motorsports.They have 1 in stock,When there's 2 needed?You think order more???????????
Question: The muzzy came with a heat lube is that just for the header bolts?
is there anything else that gets lube or is the rest dry fit?
Im not your local mechanic...LMAO
NCY had them in stock (if you can believe that) last time I was there. Gotta go down and grab myself a couple today for my new exhaust, you need another one Dan?
Yeah, I should have listened to MAGNUM OFFROAD the first time, Dan I had to order 1 so im waiting, I was trying to save the drive when i should have picked them up when i got the exhaust "idiot" now who's paying me!!!!!!!!!!
The muzzy's are bad azz, they look awsome,sound awsome, and takes off like a bat out of hell!!!!!!!!! Well worth the money, the way they mount they dont rattle anywhere like the stocker.
Rhinos doing BURNOUTS NOW !!!!!
Blaster
