Best Kawi T4 Replacement Battery
OK, I know what a good battery is so please no shots in the dark. But what battery will fit right and will be the best for my T4. I also need to add a disconnect. Either my stereo or race radio puts a constant draw out and has killed my battery too many times.
Advice?
Pc925 Odyssey batterie is the way to go look up FuelUtv they sell a nice hold down bracket where you can do a single or dual batterie setup
how about fixing the dead draw you have in your system... just saying that would fix it up right..
Throw an Odyssey in there and get yourself a battery tender and leave it hooked up while it sits. Would try to find the problem also:D Memory,clock ect on stereo will run the Batt down depending on how long the car sits between uses:) Batt Tender will fix that:cool:
Joe, I can wire in a tender for you. Under the driver seat there is room for a full size car battery.
