Yamaha 09 Crossplane SR1 Build
More then likely you will have to run your preload up on f-kit shocks for that weller kit, mine where binding a little at full droop
It really wouldn't matter what my settings are as my car out weighs yours by a good 250lbs! Just run them all the way up and drive it at low speed and listen for the binding, adjust from there. I will post a pic of low level my rear a-arms look.
A pic would help thanks
There should be no binding of the rear driveline and our kit as long as you have everything mounted in the correct locations. Also, aside from that fact, if there was, the amount of spring pre-load you have won't have anything to do with that anyways.
If you guys have a question let me know.. but it should be fine.
G-
G-
Thanks Greg, hopefully we will be testing in a couple weeks. I'll hit you up if we have any issues.
Finishing up on the body today. Some trimming on the hood and fenders and the whole car will be complete.
