All UTV's XXX Welding Porn!
I just stumbled upon this thread and decided it needed to be bumped again. There is serious art work going down in some fab shops around the country. Great work guys!!!
The corner gusset on the new XP1k we're building.
Sent from my iPad using Tapatalk HD
a little mig work....
I little mig work building Maverick receivers
This might be in the wrong place. But if any of you are in the high desert. And needs welding. My buddy loves to weld. Steel or aluminum. No job too small. Bring a pacificos. he loves those
He says he is not AWS certified. I seen his welds and they're badass. P.m. me for his number
Lots beautiful welds but I keep seeing a lot of welds being stopped at the end/corner of a gusset or other type of weldment. That's not a structurally sound way to terminate your weld. You would want to try to completely wrap the corner so you don't stop your puddle on a corner. If you can't wrap the corner than start from the corners and work towards the middle so you finish with your puddle terminations(we call them "buttons") are at least 1" from the corner of any weldment. If a weld is going to crack it will usually propagate from where the puddle was terminated. ESP with aluminum.
A "wet welder." Gotta love it!
Jumping around from section to section welding a arms
A fire pit top out of 14ga 304 for my nieghbor
Welding the balljoint boss to the body of the a arm
More Jumping around on welds
RBO
