Polaris XMF XP 900 front shock Tower
Scott@XMF
XMF Pit Slave - UTVUnderground Approved
Improve the geometry and handling of your XP with this Simple bolt on front shock tower works with stock shocks some sanding on the stock frame to fit
$195.00 powdercoated black with all hardware
Yep John it is designed to work with stock shocks it does not change the drop you do loose a little travel about 3/8" up.
The benefit is that it improves the motion ratio of the shocks allowing them to work more efficiently. I installed one and while I didn't notice the difference perse, logic tells me it works... Easy to install is another positive!
Blaster
