Will we need lights at the silverstate? Pics of FOX internal bypass shocks
high flow pistons in front you want the front to be springy. the rear was there regular piston with no bleed hole at first. then when we got closer on set up we would start to drill out cant remember wat size hole at end but very small. if you stack the side shims that are for the bypass the last hole you almost get bump stop out of it.
Thanks for the info.Were you running these on your Teryx or Razr?
