MQUnlimited
I like this alot! How do you have it anchored in to the bed? I've thought about doing this instead of buying a larger flat bed but dont know how a Polaris Ranger 800XP will feel back there.
	That looks like them.
Put air bags on your truck if you don't have them already. Makes a huge difference once you load up.
Here's another version of a SxS/ATV/Snowmobile Deck
Ramp width expands or contracts to suit whatever you're loading. Holds 2 snowmobiles or atv's side by side (sides fold down). Black material on ramp is combination ski slide and grip surface for tires. Ducktail (bed extention) for SxS comes off with 2 bolts. Ramp stores in center under bed in locked compartment. Suprisingly not that much more than aluminum sled deck and much better handling. Bed also includes 5th wheel hitch. BTW bed comes with provisions for tying down front wheels on 3 motorcycles side by side.
Silverlake Manufacturing - Flat Beds
those look like they would be perfect and are only about 50$ cheaper than I can make them for might be getting them!!!! thanks,
what does a bed like that cost. do u have a goose neck ball as well?I was originally wanting one like Crowdogs but I have been thinking about it I decided this type would be best. I like having the SXS lower and the bed could have lots of built in storage. Someone needs to build one! I've been searching for month's. I might have to break down and build my own for my F350 Dually.
have you personally seen them in use. do they flex cause the can am is heavy.
