Tensor Tires Utv Specific tires. The Regulator A/T
No better side wall bite on the market Period. No it did not go over
[/IMG]
Sold on the tires, confused on wheel off set. I'm told a +0 is to wide, what's to wide? I'm told I need a +10mm =a 4-3? Then I was told a +0 is 4-3? What's What? In a 14inch desert riding. 2014 Max
Thanks!
Sent from my 1000cc Beacon!
4+3 is two inches wider per side 5+2 is stock.
5+1 is stock so a 5+2 will make you 2" wider total than stock. A 4+3 will make you 4" wider total than stock.
According to Shock Therapy the 1000 needs a 5+2 to keep the geometry correct.
We love these tires. After two BITD races we will be taking the exact same set to the Henderson 250. This tire has proven itself at top speed on pavement and the roughest terrain anyone could encounter. I hope that anyone looking for a tire that won't need to be replaced gets a set of Tensore Regulators.
I have to agree it's a more stable feeling tire than what I had and definitely tough as nails. I haven't had a tire flat yet in 4 races. The only thing I'd suggest is running near normal tire pressures.
How tall are the 30x10x14 tensor regulators? What about the 28x10x12? I'm talking actual height. I've heard the 30" ones are actually about 28.5" ish. Anyone know the actual size on the 28"? Looking at 28" for my rzr but if they're actually only 26", I might as well get the 30".
29.5" is a good # for the 30" and 27.5
" on the 28" I have been running the 28" on my 1000 or about 1600 miles and love how you can manipulate the power. Had them out a Moab a few weeks ago and they were a blast.
Tread gapping is wider than I would have guessed for a desert tire. How much does it weigh? 15" only?
The New DS 32x10x15 come in a at 34.5 lbs. This is the lightest 32 on the market. it was Raced in the Baja 500 and a few of the local desert races with zero issues.
