Shock Therapy First Impressions Polaris XPT Dynamix
Shock Therapy
Suspension Tuning
Hey guys here is a little video we put together during some of the Dynamix testing to give you an idea of how cool the system is and our plans for improvements coming up. Currently we have spring kits dialed in. We also have shock internals set up and ready to go. We are working on electronic systems that will enable you to tune your shocks individually as well as wider adjustments. All coming soon.
Intrigued to see what you guys come up with on the programming/electronic side of tuning the system, in conjunction with the physical springs/valving side.
Currently we are working on two things.
One, the ability to tune the front shocks separately from the rear via a switch/knob on the dash. If you needed more rear stiffness because you loaded the cooler and tire on the car, you could stiffen just the rears. The Dynamix only allows you to stiffen the car all four shocks at a time currently. This kit will be available very soon.
Two, we will have ECM flashes for the shock control as well. This will have the potential to change the complete characteristics of the system. How it stiffens up, how it progresses through compression, body roll, anti dive, rear squat, ect. This flash will be a ways out.
KpALMA
