drew schultz 320
So I purchased a HPD Heavy duty rear diff for my 2008 RZR 800 and had a few questions. Should I just put new bearings in it while I have it apart and where is the best place to get them.
Should I get the rear diff lined up again since Im not using the stock cases. I have the shim stacks from the stocker still but not sure if they are going to be the same set up with new cases. I think its called setting the pinion depth?
Thanks for any help you guys can provide!!
