MTNTK Performance
The Blow Hole was developed out of a desperate need to increase belt and clutch life. In the extreme conditions belt covers are removed in an attempt to prevent belt failures, but leads to premature clutch wear and failure. The clutches and drive belt show up as a weak link as the added load is converted to wasted heat energy. This waste heat deteriorates drive belts, and breaks down composite bearing surfaces and parts which lead to increased inefficiency. UTV’s place extreme loads on their clutches and belt which builds extreme heat. This heat, in turn, will end up costing you money and riding time. It leads to premature wear on your clutches, and complete belt and clutch failure. The Blow Hole places a high output auxiliary fan in the cooling ducts of your clutch housing. It dramatically reduces ultimate temperatures generated in the clutch system and also speeds cooling of the clutch housing when traveling at lower speeds between high load events. With true plug and play OEM connectors, the Blow Hole is a must for any UTV enthusiast.
Available for: Polaris RZR Turbo, RZR 900 Trail, RZR 900 XC, RZR 900 S, RZR 800, RZR 570, RZR 1000 S, RZR XP1000, RZR XP900, General and Ranger.
