matthewsmith
2013 Bennche Bighorn 700 EFI
I just picked up this project that I was told would crank, but not start. This is what I’ve figured out so far….
I installed a new battery and get all dash lights, head lights, and brake lights on when turning the ignition on. Fuel pump even turns on. It does not crank with the key, but would when I jumped the starter solenoid, so I replaced it…..no change.
Figured I’d check for spark and compression while I was dorking around. Compression is 110 psi, but there is no spark. Replaced the spark plug… no change.
So, is my new starter solenoid bad? Could it be the brake or gear position switches even though the brakes and neutral lights come on? Not sure where to go from here. Any and all help greatly appreciated!
