Can-Am Need help, Dobeck AFR 4+.
doesn't matter how much fuel you put in it at idle stock computer takes over. From the PC5. we have been using a company in town that brakes into stock ecu been getting a lot better. we are getting both ecu back today to test.
Any updates ?
From ' The Land Down Under ' .
I can adjust a/f ratio's at idle when I do my reflashes, and it has helped, but even with a corrected a/f ratio at idle it still doesn't want to return to an idle after a rev in neutral... I am getting close.
Nate
Alba Racing
Nate, what a/f ratio at idle have you found to be acceptable ?
Are you guys running Gen 1 type cams or Gen 2 ? ie fixed sprocket or indexable ?
Trying to resolve my idle issues I have tried everything from 11.5:1 all the way to 14.5:1 and that is through re-flashing and not a controller of any type.
Nate
Alba Racing
Blaster
