Hid for 2011 rzr s
VBosch02
I got an HID conversion kit for my 2011 rzr s. When I bought them the guy at the counter said plug and play. Right!!! Has anyone done the conversion with the high low beam? If so can you give me some info on how to install? :confused:
Thanks
did you get high low conversion kit?
if not you need to tap into the high or low beam wire to trigger the ballasts.
I prefer a realy inline for that though.
it is pretty easy if you have any 12 volt and wiring sense.
I did get the high low conversion kit.
if it is true plug and play, then it should plug into the harness side of the headlight socket.
