dual battery set up
1904 rhino
I have 2 batteries that im trying to hook up in my rhino. I have a dual battery switch that has an off position,batt 1, batt 2, and common. I know that the cable coming from the starter has to go to common. From batt 1 on the back of the switch I ran the cable to the little fuse block in front of the stock battery where the starter cable used to go. All I get is a buzzing noise and the starter spins but doesn't engage. I have wired tons of trucks like this with no problems. I'm out of Ideas on what to do. Any one have any suggestions?
images
this is how my car was wired...
I went to a dual battery relay system,
one battery is for starting & the other is for Acc.
when the key is turned in the on position, booth batteries are linked together.. .
Thanks for the info. I just figured out what I had done wrong. Both the ground and the starter cable come up into the battery compartment togeather and like an idiot I had them switched. I appreciate your reply and diagram
