28" Tires and Clutching
valco
Those of you that went with a 28" tire vs a 30", did you still add a clutch?
I have heard it's a must with 30" tires, but I'm getting mixed info for a 28" tire.
Any advice would be appreciated.
Joey, did you clutch the Black Mamba with the 28" Mongrels?
I ran my xp4 with stock clutching and 28" moto mtc with zero issues. I have several buddies running 30's on there xp4's with zero issues. One has 30" bighorns, 1 has mongrels and another has blackwaters. You will be fine
Thanks copperhead. You see any advantage or disadvantage between the 28" and 30" between your buddies?
on a 4 seater for sure do 30's. they need the extra ground clerance. Im not a fan on mongrels. the bighorns work very well on my buddies. Roctanes are another good one
