badassmav
That's awesome! A weekend warrior grabbing the bull by the horns.your pics and detailed explanation of why you did it, are very rare in this sport. Most teams keep everything quiet from build materials to their learning pains.
i understand wanting to keep everything quiet but dont forget about us little guys who learn from you and your trials and tribulations.
btw just from your pictures and explanation of how you moved the rear diff back i decided on chopping mine this summer and getting more whelbase.
Thanks BA
 That's too cool!  Ballsy, to say the least.  I'll offer any advice I can to help make your project go as smoothly as possible.
 That's too cool!  Ballsy, to say the least.  I'll offer any advice I can to help make your project go as smoothly as possible.  Extending the sway bar arms? Upgrading the coil-overs? How much wider are you going, if at all? So many juicy questions I have for you!
So, are you building arms also? I think HCR or Lonestar offers +4 or 5" arms that extend the rear axle centerline back 3". Although I would NEVER recommend moving the axles only back that far, those arms would be right at home w/ the rear diff re-located. Use caution when deciding on how much length to adjust your axles by. Now that they will be properly aligned with the diff, they will plunge much deeper than did the stock axles that were swept back. I believe the minimum amount that you can move back the diff was 7 3/4" or 8" to allow adequate clearance between the inner cv joint bodies and the factory rear control arm pivot bracket that vwertically ties in the parallel tubes. I moved ours 8 1/2" to take full advantage of the rules regarding wheelbase extending. The rear drive shaft will also need to be lenghtened by just under the amount that you moved the diff back.
Also, it was really tight squeezing the diff between the stock paralell tubes that terminate behind the diff. Since you will be removing the lower cross-over tube that ties in the frame behind the diff, you'll need to fab a cross-over support that uses the upper rear control arm pivots as mounting points. Try to design the mod so you can still remove the rear diff by pulling it out from the rear, as per OEM design. It is much more maintenance friendly if you can make it happen. Ours has to drop in from the top, with the fuel cell out. So, to yank my motor or replace a drive shaft, I must first remove a coil over shock from either side, then the fuel cell, then the rear rotors, hubs brakes and axles. Then, that pesky bolt that attatches the driveshaft yolk to the output shaft in the rear diff. Finally, I can pull the diff up from within the fuel cell framework. Fortunately, our robust design never let us down during a race, therefore it has not been an issue.
The tightest squeeze will be fabricating a new rear toe link. Where before, it ran behind the axle, it will now pass underneath the axle. There's room for it to go there, you just have to cycle the suspension and confirm clearances.
Your stock cv joints are good for 25 degrees of reliable deflection when they are properly aligned. You will also notice a significant increase in acceleration, as you have now returned to the rear wheels the horsepower that Can-am robbed from them by sweeping the axles back.
Hope I didn't scare you away from your plans! I'll be here every step of the way for you. Just let me know. Good luck MDD!!
