All UTV's Transportable & Removable LED Dome Light Kit For UTVs
Transportable & Removable LED Dome Light Kit For UTVs​
Mesa, AZ January 18, 2013 — Anyone who has ever been out in their UTV at night has noticed that it can get hard to see anything inside the cab. DragonFire’s bright idea was to create a dome light kit… of course in typical fashion, it was over-engineered from the start! High intensity LED bulbs and a stainless spring steel mounting bracket were just the starting point for this over-the-top lighting set-up.
“Our LED Dome Light was designed to be as useful as possible while staying simple,†explains DragonFire’s marketing go-to guy, Chris Moore. “We developed a 304 stainless steel mounting basket that attaches to almost any 1½†-2†diameter cage tube. Low profile zip ties secure the mount to the cage tube with no need for welding or wrenches... again part of our design brief to keep things clean and simple."
The light itself is battery powered, so there is no need to worry about trying to tie into the electrical system or run wiring throughout the cockpit. The multi-function LED light features a flood light top portion, side spot flashlight, magnetic backing and even a useful pop out hanging hook. The best part of this whole set-up is the light slides in and out of the mount with ease, making it not only a great dome light but also a portable hand held work light as well. This kit is a great inexpensive gift so don’t leave your friends, family or yourself in the dark again!
Features:
Mount made of 304 stainless steel
Simple zip-tie mounting system
Multi-function LED light
No wiring or welding required
Removable light doubles as a flashlight/work light
Low draw LEDs last a long time
For all the details regarding DragonFire’s bright idea dome light, click here:
http://www.dragonfireracing.com/battery-powered-led-dome-light-kit.aspx
And while you are navigating your way around the world wide web, be sure to “Like†DragonFire on Facebook: www.facebook.com/DragonFireRacing
Hickoryjoe
