STETLER's R1 Rhino by 151 Fabrication
Ok, So after the last Glamis night ride I came to realize that the HID lights I was running weren't cutting it. I was running 8000K temp bulbs at 35W but only 2 of them would work. So I tossed those in the trash and went with new 55W Ballast and Bulbs in a 6000K Light temp. I also went with the new Slim ballast to cut down some weight and make a little more room between the light housings. Here's some pics of the old and new set up.
Old:
NEW:
I temp strapped everything on with tie-wraps and wired them up, Then plugged it in to make sure everything works.
Then I drilled out the holes to mount the Ballast and installed some SS Socket heads bolts and Nylon nuts for a more secure and better looking mount.
Also installed a New battery & Battery Cut off switch so my GPS doesn't run down my battery.
55 watt is friggin bright. you will love seeing 1/2 mile in front of you. you will blind people at night.
when you need an alternator let me know i have the adapters.
Not sure if I'll need it yet but very interisted in your alt. set up.
Is it universal for a motorcycle engine or is it made for certain year R1's
Got any pics?
Took off the Sand tires and threw on the Dirt tires . Ready for some Barstow runs this summer.
Just regeared it and it's running like a Grape Ape !
