SDSU Mechanical Engineering Senior Project Design: Custom Rhino ATV
vsanchez
Hello to all,
I'm part of a group of 6 that will be developing a new chassis/suspension design concept for a custom Rhino ATV. Successful completion of this project will fulfill all senior design class requirements. We are all rookies, so any help will be greatly appreciated.
Hope all is well on your end.
Thanks in advance.
-Victor
Hello to all,
Thanks in advance.
-Victor
Sounds like a cool project. There is already your standard a-arm and now trailing arm setups out. Maybe a cantilever design would be worth looking into to keep it "new". I have not seen one done that way yet. It would allow shorter shocks to be used due to triangulation.
CHECK OUT TROPHY TRUCKS FOR SOME IDEAS ON CANTILEAVER REAR ENDS. READ UP ON BY-PASS SHOCKS, BUMP STOPS & OTHER THINGS USED IN OFFROAD RACING.
welcome to the site Victor. Are you guys starting with a RHino or are you going to build it up from Scratch?
Thanks for the welcome. This sport is very new to me, but it's fun and I'm ready to learn a great deal and also help other in the process.
No. We plan to use a stock Rhino base frame and design our chassis/suspension to mount to it. I made a rough SolidWorks model of a stock base frame using some pictures....it's a start for now. I have been looking all over the place for a website that would give me dimensions for the base frame....and still no luck.
So at the moment, we are looking for someone that has a base frame we could pull dimensions from or maybe even buy.
my little sis goes to sdsu. i have a kawi teryx if your guys need something to look at that has already been modified for ideas. im located in escondido so not to far away. also there are quiet a few vendors such as black rhino that are close to the sdsu that make some great products and have alot of knowledge to help with the build. good luck . lets us know when you get to the testing phase would love to see how she runs.
Hello to all,
Thanks in advance.
-Victor
I wish my son who is going to NAU would have done this project LOL BTW he has a job all lined up here in SD after he graduates on May 14th WOOHOO
I wouldld bet Chris from Benchmark performance would help you hand over fist!!
From what I have seen so far, the A-arm setup is used for the front suspension while a trailing arm is used for the rear. Will a trailing arm setup, by design, absorb more shock than a cantilever?
That would be great! let me know when your available. Also would you happen to have some pics of your teryx?
Nice, good for him. I graduate till this fall, so I'm almost done. Where will he be working at? Maybe you guys could pitch in some ideas???
The Rhino uses double a-arm front and rear. The Commander and RZR XP use a trailing arm rear, however they are slightly different from one another. Member Steve from Makn' Trax suspension has built a custom trailing arm Rhino. You may want to ping him. The trailin g arm setup get rid of wheel scrub and allows more travel through triangulation... In an a-arm setup the more travel yopu want the farther out to the sides your wheels must go as the arms get longer. On a trailing arm setup your rea wheels will go back further for more travel, but you can only go so far before CV binding.
Incorporate a front steering system so the tie rods are in tension like a car or truck and not in compression so the steering racks and tie rods are not always bending and breaking.:D
