Roll Cage Mounting Solutions from Rugged
RuggedRadios
With the Rugged Radios Bar Mounts, mounting accessories to your roll cage has never been so easy! The Rugged bar mounts are machined from billet aluminium and simply clamp onto your roll cage. No welding is required, and you won't have to worry about rust.
These mounts are strong and come in a variety of sizes that can be used with a ton of accessories. More often than not, your imagination is the only limit! To give you an idea on how these can be used, we use them to secure our MAC air pumper systems, radio antennas, intercoms, number / name plates, headset hangers, intercom cables, GOPro cameras, speakers, and handheld radios.
Below are a few examples:
External speaker secured with bar mounts.
RH-5R handheld radio w/ radio box secured using a bar mount. This RH-5R is hooked up to a VHF External Antenna Kit for handheld radios.
MAC1 air pumper system secured with bar mounts.
Number/Name plate using the 1" bar mounts.
Rugged Radios bar mounts come in 4 different sizes (1", 1.5", 1.75", and 2") and 2 different colors (black and polished). These 4 sizes cover just about all the standard bar sizes you will see being used in a fully caged vehicle. In the UTV market, the RZR, Teryx, and Wildcat all use 1.75'' bars and the Can Am Maverick and Commander use 2''.
Our main objective with the Rugged Radios bar mounts is to provide customers with a quality mounting solution that is light weight, rust-free and easy to use. The unique half clamp design ensures it will not interfere with any panels or dashboards. Its versatility allows it to be combined with other accessories we offer so that almost any mounting challenge can be overcome.
Other accessories that use bar mounts:
Antenna Mount for Horizontal Tube (ANT-BM-HORIZONTAL) Provides easy and adjustable options for positioning your antenna for best reception and performance. Our new design features two choices for horizontal bar placement. An inline option extends reach outward, perpendicular to the horizontal bar. The right angle option drops the antenna mount down and away from obstructions, like the roof tapering over the bar.
Antenna Mount for Vertical Tube (ANT-BM-VERT) Specifically developed to address the needs of antenna mounting on vertical roll cage tubing. No welding, no drilling, no mess! Need to relocate your antenna? Simply unbolt the mount and move it!
Single and Dual Headset Hangers (HANGER-S-UNI) (HANGER-D-UNI) Billet machined headset hangers with a half clamp design, perfect for holding your expensive headset or helmet securely and out of the way when not in use. Unique design does not interfere with roof panels or require removal of any plating or roofing to install. Comes with a band used to secure the headsets. Available in multiple size options to accommodate virtually any vehicle on the market.
Bar Mount for GoPro Camera (ANT-BM-CLAMP-GO) Allows for stable video footage while keeping the camera safe and secure. The billet aluminium bar mount clamp can easily be moved anywhere on the car. If you own a GoPro, don't forget about the music and audio recording cable required to capture intercom audio on your camera. * Does not come with the tripod mount for the camera shown in the picture, which can be purchased here from GoPro's store.
Dual Nexus Jack Bar Mount (JM-D-BM-NXS) Allows you to configure the jack position with multiple options. Once you determine the placement option, your intercom cables are secured with tiny set screws, allowing quick and convenient jack mount solutions.
I need 2 of these ASAP!
Can you guys email me joeyd@utvunderground.com so I can pay!?
Sure thing Joey, I sent your email over to the sales department so you should be hearing from them shortly.
