rhino front diff seal help
Haagsma Racing
the rubber on the driver side seal is missing a chunk causing a leak. does anyone know how to replace the seal?
its on a 2007 yamaha rhino
Court is right. Its just a push in seal. If I were you Id take the diff out and weld your ring gear bolts also before you have a blown out diff. Call me if you want more info on this.
I just minutes ago did the pass side on mine. It pushed 90% of te way in by hand. Tapped it in with a socket and extension the last little bit. 45 min job start to finish.
