Protect Your Tires with Pro Series Tire Sealant
HighLifter Underground
High Lifter Employee
Lock in air and lock out leaks with High Lifter's Pro Series Tire Sealant! Our economical, easy to use, and safe sealant was formulated and tested for use in all ATV and dirt bike tires.
Pro Series Tire Sealant seals punctures up to 1/2" in the tread and up to 1/4" in the sidewall! It also stops bead leaks and pinhole leaks in wheels. The Pro Series Tire Sealant prevents 90-95% of common tire failures. Wounds or punctures are plugged instantly and PERMANENTLY. 32 oz. per tire recommended. CLICK HERE to order Pro Series Tire Sealant!
JasonL@HighLifter.com
