Roughest race I can remember.
If you don't mind Lacrecia, may I make an observation about your broken shocks? It is my guess that you broke the rear shocks, and that they snapped at the lower section of the shock shaft, just before it attaches to the bottom eyelet that bolts to the a arm. I noticed in your build here that your cars' shock mounts share the same mounting orientation as the stock Maverick. If they have not yet broke, they will eventually.It was definitely a rough course. Broke 2 shocks and ended our day as a DNF...again...I only have one thing to brag about, our 1st lap at 31 min! Feel pretty good about that. Now, if I can only keep my car together, I know I can catch a lot you boys out there!![]()
Notice on the attached image, our rear shock mounting bolt, and how it is mounted in the same direction as the a arm pivot, and is mounted at an angle perpendicular to the shock pivot axis. Now, look a picture of the stock rear Maverick lower shock mount, and if you can visualize the swing of the a arm, you will see that the motion of the a arm introduces a bending load on the shock shaft due to the orientation of the lower shock mounting bolt, and the position of the upper shock mount. The top shock mounting position only complicates this problem, because it is mounted far in front of, not square to, and outside of, the upper arm pivots, instead of in between them. Because of the placement of the upper and lower shock mounts, every time the shock strokes, it is like bending a piece of metal back and forth, until its eventual failure. The Murray's experienced the same problem at the Parker race at the beginning of the season. They hit a hard g-out, and sheared off both shock eyes, in exactly the same place, and at the same time. They replaced the old 5/8" shafts with 7/8" shafts, and I believe they have had no more issues breaking shocks. Although the proper solution is not a beefier shock shaft, it was an easier fix than re-mounting the shock absorbers.
I was tracking the race online, and hated to see you dnf. If we're not racing, I always root for the underdog, but once you address these issues, an underdog you will no longer be. I hope you will consider my suggestions. Baja is going to be a long race, and I'd hate to see you suffer from the same consequences that you did last weekend. As we experienced last year, it kinda' takes the fun out of racing when you dnf.Good luck next month!
I would cut the back half the car off and put 2015 rear section on and put the longer rear shocks on.
Jim is correct. Welding a clip on from a newer model year is the same thing as altering the stock pivot points, and would not be allowed in our class. The new shock location on the 2015's has room for improvement, so it wouldn't be worth the effort to use anyway. But, back to the solution to Lacrecia's problem.I would cut the back half the car off and put 2015 rear section on and put the longer rear shocks on.
How lame is that? One would hope it was just a random idiot f-ing with an exposed race car, but the fact that both of the rear clickers were backed all the way out leads me to believe a racer, or a fan of Team Polaris thought they would sabotage the Murray's efforts.Leucrcia I could feel your pain from the beach in Maui. Loved the internet tracking this particular race! As Reid said the Murrays had the same problem earlier this year....two shock shafts snapped in same whoop. Reid also explained our "quick fix". I'm sure you will be running up front soon as you eliminate the issues of a new race car.
Speaking of shocks and this weekend....the 1917 had a problem also. The Murray's had the 1917 parked on their "open" trailer Saturday night down by the boat ramp, near another team truck and in view from 1917 team hotel room. Regardless, someone came by that night and messed with the rebound settings of both rear shocks which can be done so easily. Once Jason and Derek took off Sunday they knew something was horribly wrong once the shocks warmed up resulting with the rear end pounding into every deep whoop. Derek had actually adjusted the rebound the night before to compensate for what was to be a much rougher course on Sunday. With each lap the rear skid plate came looser due to the pounding and eventually became a scoop that hung down 6" and kept peeling back as the race went on. They stopped in the pit to see if it could be repaired/removed but couldn't in a timely fashion. Once the race was over he, Jason and team debated what could have caused the problem. When Derek went to count the "click" settings he discovered someone had backed the screws all the way out of both rear shocks.!! Lesson learned was we will no longer park our vehicle on an open trailer ever again. See you in Baja!
You sure one of those guys didnt go the wrong way on the adjuster? I cant say I know all the folks in the class but the ones I do know wouldn't mess with another teams car.
Jim,
I totally agree with you about the teams we have raced with in this class. Unfortunately this happened and it's our fault for not having the vehicle in an enclosed trailer.
FWIW: Shocks were recently rebuilt to our Fox/team mutually agreeable settings from last shock test session. Derek knows what he's doing and keeps a log on the factory settings & any subsequent adjustments between races/rebuilds. Saturday they worked perfectly.
