![](/proxy.php?image=https%3A%2F%2Fci3.googleusercontent.com%2Fproxy%2FeOfjV-vc2nnwiYh288W5JJBni0feQPjNtJvmZscn8wkP2T3t3zJeBgr2mzuMP1KCVnLD40gofof_Gfw769TzZCxRUDRkWDLLbyhu3vnGMV7h0fgyjBoZttG7ccY%3Ds0-d-e1-ft%23http%3A%2F%2Fimages.mitekusa.com%2FConstantContact%2FMTXAudio%2FMTX-Audio-Logo.png&hash=313f242e1f821027207560b2d7281f55)
![](/proxy.php?image=https%3A%2F%2Fci6.googleusercontent.com%2Fproxy%2Fc9rL0_DBKIyfnN4x0kebYatk7f-GCPIAfqbrXLCuj4Jnldc1OlUH8uVhyr9dA7UvDVEtaKmz9x3gjWCVgH4QLoAywegCl1dxm4IYb6QGTk7vc3ofrPE%3Ds0-d-e1-ft%23http%3A%2F%2Fimages.mitekusa.com%2FConstantContact%2FMTXAudio%2FMUDSYS31.png&hash=ba8ae31698ac37a46da60dc20e131691)
The MTX MUDSYS31 Bluetooth overhead audio system delivers unbeatable, high-quality audio to UTV's that include mounting-accessible roll cages. This all-weather system includes four 6.5" coaxial speakers that work in conjunction with an integrated 280-watt power amplifier. Sources include Bluetooth, 3.5mm auxiliary, and a digital AM/FM radio that allow you to listen to your music however you want.
The unit also includes a USB charging port to keep phones and other personal accessories powered up, a digital clock, and LED map light.
The MUDSYS31 mounts easily to roll cages with included hardware. It is the perfect solution for Polaris RZR XP900's, XP1000's, and other machines with narrow cages. It fits roll cages with inside measurements of 32.25" to 38.75" and bars 1.75" to 2" in diameter.
With an IP66 all-weather rating, the MUDSYS31 will take the abuse of the trails and Mother Nature. The unit is prewired with power, ground, and accessory wires for easy installation and connection to your vehicle's electrical system.
For UTV's with larger roll cages, we also have the MUDSYS41 and MUDSYS46. Or, the MUD6SPBT offers the maximum mounting flexibility in our line of universal sound bars. All models are very easy to install.
![](/proxy.php?image=https%3A%2F%2Fci6.googleusercontent.com%2Fproxy%2F_lNTSHvuP6qRMxpXEieGyMKxNtsxs6Wp0B8598qvMMgPY4p8pIIqXKDJuVBIRD8jlp6Ry1VHvTb-h9TVSXT8IeujB4mrBd7qwaCegFdxGkseX-6Sr_pNKpR_D8dc231g%3Ds0-d-e1-ft%23http%3A%2F%2Fimages.mitekusa.com%2FConstantContact%2FMTXAudio%2FMUDSYS_install_vid.jpg&hash=1a34f772829f5480123512da93231884)
![](/proxy.php?image=https%3A%2F%2Fci4.googleusercontent.com%2Fproxy%2FZP9vJx5iBVWTEAuFkU60FDEErnWbg6lTXRCW8adht6kXd5ArrYNk33ndhfJAvfQIgpctc5lsLor4omvjU9rBefDpnCmZvmMCXbO_gZBAbctU-pEWF1xEsWhEqvWF-w%3Ds0-d-e1-ft%23http%3A%2F%2Fimages.mitekusa.com%2FConstantContact%2FMTXAudio%2FMUDSYS31_diagram.png&hash=39ebe04362ae02d599793f4d3991e354)
RZRPOD65 is the best solution for adding speakers to your RZR XP1000 or XP900. No more mounting speakers on the outside of your cage where they can get damaged. You don't have ears on your feet so why settle for kick panel speakers? The RZRPOD65 delivers high performance audio in a location where you will actually hear it.
![](/proxy.php?image=https%3A%2F%2Fci4.googleusercontent.com%2Fproxy%2FVuNXElgalc_DWDGVVA5WJ0H8ay5620TnzwPZL8cfGF0hsoKBuyxqzTN0QXUKduZmHwcYHTr9xn2FrRpaJrjj54tlI62KgU3KP28r8NC_6xal0v3z9mZQqqwPOjwY_O6qNwu7hOl6eg%3Ds0-d-e1-ft%23http%3A%2F%2Fimages.mitekusa.com%2FConstantContact%2FMTXAudio%2Frzrpod65_speaker_pods_720.png&hash=1de8835e3c1dd29938e56ad4f21b1294)
The speaker pods are designed to mount directly to the dash/cage of specific Polaris RZR models. The pods are rotationally molded using polypropylene creating a durable finish that is weather and UV resistant with an IP66 rating. The pods mount in existing dash locations and do not require any cutting or drilling to install. Each pod also includes a weather resistant 6.5" coaxial speaker featuring a polypropylene cone and clear Teteron tweeter that deliver exceptional full range clarity. The mounting location is ideal for sound staging as the speakers mount directly in front of the driver and passenger ensuring music can be heard clearly even at high speeds.
![](/proxy.php?image=https%3A%2F%2Fci6.googleusercontent.com%2Fproxy%2F_RgO6ClUYnom3jNyL-6PD8On0w_wxhni0Eqa2-FGhL93thEDKlPM6R2fGBowwNAKp3lMD0n9gWQv9EyRxP8BYZ9JFihHWBURUklmyIyvj5LnLbzW4LusL1lZ9adqWQ%3Ds0-d-e1-ft%23http%3A%2F%2Fimages.mitekusa.com%2FConstantContact%2FMTXAudio%2Frzrpod65_install.jpg&hash=8569c0ba300ae143bfe5a303f5e8eb71)
![](/proxy.php?image=https%3A%2F%2Fci5.googleusercontent.com%2Fproxy%2FU1KNJgw0LVf_t3n6Lv8VQlha7seGrvu1biqa_zflQDUlNc1_KdVVwOa_h2iIeF456qDiCnodPxNIWeFcWcnUWhB2ULeWCE0ghMlbTbbXjGmXpw%3Ds0-d-e1-ft%23http%3A%2F%2Fimages.mitekusa.com%2FConstantContact%2FMTXAudio%2Fip66.png&hash=6cfe1261d2c8f13608f87b9c67765a38)
What does IP66 Rating mean to you?
An International Protection (IP) Rating classifies the degrees of protection provided against solid objects, dust, debris, accidental contact, and water in electrical enclosures. The standard aims to provide consumers with more detailed information than a vague marketing term such as "waterproof."
The first digit in the MUDSYS31 IP66 rating indicates the level of protection the enclosure provides for the electrical conductors inside and the ability for solid foreign objects to get inside. A rating of 6 is the highest rating and certifies the enclosure to be dust tight with complete protection against outside contact of solid objects.
The second digit, also a 6, indicates the level of protection from liquids. Another 6 rating validates the enclosure to be able to withstand water projected on the enclosure, by a nozzle, from any direction. A 6 rating is just short of being able to withstand being submersed in water up to 3 feet. (Let's be honest, if you submerse your UTV in water where the roof is 3 feet blow the surface, you've got bigger problems.)
What does all this mean? It means you can rest assured that our IP66 rated products can withstand the abuse you will put it through while riding the dusty trails, getting caught in the rain, and bashing through mud pits. It means you can easily wash your machine without having to worry about removing your system first or getting the system wet.
mtx.com.
Interested in becoming a dealer? Call 1-800-CALL-MTX (225-5689) or visit us online at mtx.com/dealer_intro.
About MTX Audio
MTX Audio is a family-owned, American manufacturer of high-performance car, marine, home, and street audio products. MTX is one of the leading companies in the mobile audio industry and builds innovative and easy to install products for the audio specialty dealers and consumers who are truly "serious about sound."®
©2016 Mitek Corporation. All rights reserved. MTX is a trademark of Mitek Corporation. All other trademarks are property of their respective owners.
