Yamaha humming/grinding noise at idle in high
blewis00
hey guys I recently put in a new machined sheave and new oem belt with duner clutch springs, weights, slides etc. everything moves nicely when in nuetral however when i shift into high or reverse i hear a humming noise at idle which goes away under load. I also blew up a belt after the install but that was a dayco aftermarket which i think im chalking up to being a POS. It is also hard to shift from high to neutral. I have to shift to reverse then back up to neutral. That and the noise concern me. Ideas?? thanks.
I disassembled and reassembled the primary, and re-greased all the weights. everything is sliding correctly. havent checked the springs. the clutch assembly seams to be working fine.
please explain further. what would cause it to run smoothly in neutral and not in high drive.....until there is a load put on it. when i hit the gas the noise goes away. thanks
