Front CV Joint
redrhino99
Redrhino99
I already removed one of my rear cv joint's and axle. Then replaced it with a new one. Very easy. But my front inner cv joint boot is leaking & will not come out. All I want to do is take it off & replace the boot. Is there a trick to it? Any info is appreciated.
they are a pain sometimes ... its a dry socket unlike the rear. So they get really stuck in there after a short time. I get it out with two small pry bars or screw divers on apposing sides of the CV ... its a two people job. If you pull axle ... it pulls out of the CV 9 times out 10 before the CV comes out of the diff.
hope that helps!!
