FEATURE PRODUCT: SDR MOTORSPORTS HI-BRED DOORS
We are huge fans of the SDR Motorsports Hi-Bred doors for both two & four seat RZRs. We have ran these doors on three of our most high profile builds over the past year. The fit, finish and ease of installation makes them the nicest doors on the market and the high quality machined hinge is what sets these doors apart from the rest. While many companies spend their time searching for a way to make their door stand out, SDR perfected a clean and simple look that follows the lines of the machine and provides the protection you need. Using the factory latch mechanism makes for easy installation and replacement. We have not had one problem with our doors.
CLICK HERE FOR TWO SEAT DOOR INFORMATION
CLICK HERE FOR FOUR SEAT DOOR INFORMATION (FRONT)
CLICK HERE FOR FOUR SEAT DOOR INFORMATION (REAR)
The Hi-Bred revolution continues….With over a year in development and testing our new bolt on doors are ready for your ride! We did not just copy the factory doors, We started with a clean sheet of paper and and set out to design and build a set of doors that are rattle free, easy to install and adjust, are strong, and completely serviceable over the years ensuring they work perfect for years to come?.It all started with our patent pending single pivot aluminum hinge. We did not settle for a gate hinge or re-purposed fence hardware, we designed our new hinge from the ground up, specifically for our doors. We had a tough act to follow given our old weld in doors where the industry standard and most copied design and hinge on the market, but we set the standard before, and we have done it again!…Styled and designed to look more like a custom fixed door instead of a bolt on door we feature full length 1 piece 3-D formed aluminum panels that are Dzus buttoned on and look as good as they work! This exclusive design allows maximum opening room to get in and out of your car. Doors are sold in sets. Join the Hi-Bred evolution today….
Technical Details
  • Industry exclusive aluminum single pivot hinge
  • Delrin bushings on pivot for smooth rattle free operation
  • Designed to work with both stock and most aftermarket cages
  • Widest opening doors on the market
  • Custom design 3D door panels
  • 100% Bolt on installation
  • Made in the USA
  • 100% D.O.M. tubing
