All UTV's Dream utv build
Spicoli
Lets here what kind of ideas you would come up with if money didnt matter. Start with which platform and then get wild!
Sent from my DROID BIONIC using Tapatalk 2
Yamaha rhino, mid travel kit, heavy duty axles and drive shafts, can am maverick 1000 engine, lowered aluminum cage, swap over can am gauge cluster, 26 x9 bighorns on bead locks, led light bars on bumper on front and rear and all the way around the roll cage, camoplast 4s tracks for the winter, full cab encloser, full skid plates, LBZ Duramax and a 2013 dodge cummins with a six speed stick to alternate towing it it.:rolleyes::D:D:cool:
Teryx based, tube chassis, motor with the works, trailing arm rear suspension, c/o and by-passes on all corners, 30" tires...
I'd start there then fill in the details later.
I got to build my dream rzr! 500+hp single seat center drive rzr 4!:D:D:D:D:D
OK I'll play!
Base Platform, XP4 LE
Full tubed chromoly chassis with real integrated bumpers & doors.
Extend wheel base to 110 inches, adding the 3 inches in the rear passenger floor area. 3 inches would add allot of rear seat leg room. 68 inch track width.
Suspension; a true 15 inches of front travel with a true 17 in the rear. Box plated lower fronts, tube uppers on spherical hiems instead of ball joints. Box plated rears with spherical & hiem radius rods. 2.5 internal bypass coil-over front shock with 2x12 inch remote reservoir. 3 inch rear internal bypass coil-over with 2.5x12 inch remote reservoir.
Engine; A real 1,001 CC Prostar engine with approx 100 hp. UPM style air filter canister & intake box. 25% larger radiator
Transmission; CVT that can be shifted from full auto to 3 speed manual shift on the fly. Electric inline blower fan to cool the carbon drive belt. 20% larger CV joints with 300m Gun drilled axles. 15% larger brakes. 4 wheel drive unit that does not disengage after 30 mph.
15 inch wheels with 30+ inch tires. (Brand your choice) Spare tire rack in the bed.
15 gal fuel tank
Creature comforts; Larger full dash with glove box, built in GPS, Speedo, water & oil gauges. Curved glass windshield (removable) 14 inch steering wheel with integrated push to talk & horn buttons. 4 seat Blue tooth intercom unit & 75 watt radio. 2 temp setting heated seats (Seat Brand your choice) with 3 inch Simpson Latch FX seat belts and snap in hardware. Aluminum seat bases. Four 6 inch 75w HID lights and a electrical system to carry everything.
Slackers ''SHORT BUS'' that thing goes every were and it would need only one mod. a new drivers seat , he tends to be little gassy :D
Narrow body, so either 800 rzr or rhino. Maverick motor. Rhino 4x4 drive train beefed up. Two feet clearance. High output stator for accessories. 30" zillas for tires. Power steering.
Brand New Silver LE XP 4 with EPS converted to a 2 Seater with Turbo'd Apex Power...
*** Denotes Purchased Parts & Accessories ***
High Lited Items Denotes Yet To Be Purchased
UTVINC Custom Cage with (2) Grab Handles & (3) Tab Mounts & 40" Rigid LED Light Mount
UTVINC 1 Piece Roof
UTVINC Etched Swede Roof Liner
UTVINC Doors (2) doors open and solid rear panels
UTVINC Etched Swede Door Liners
UTVINC Billet Door Handles
UTVINC Billet Custom Dash With GPS Mount
UTVINC (2) Skat Buffs Front Tires
UTVINC (2) Skat 14 Paddle Extremes Rear Paddles
18 Gallon Fuel Cell (BMP)
UTVINC 5 pt. Harnesses ***
UTVINC TS Custom Heated Seats ***
UTVINC Seat Lowering Bases ***
UTVINC Custom Engraved Switches
UTVINC Auto Meter C 2 Gauges ***
UTVINC HD Tie Rods ***
UTVINC Parking Brake ***
UTVINC Sun Visors (2) ***
UTVINC Quick Light Fiber Optic Whips (2) Red ***
UTVINC 40" Rigid Series E LED Light ***
UTVINC 1 pc. UHMW Skid Plate (full coverage) ***
UTVINC Full XP Gusset Kit ***
UTVINC Parker Pumper ***
UTVINC Radio Stack Rack ***
UTVINC G-Force Helmets (2) ***
UTVINC Rugged Radios 50 Watt with Intercom & OTH Carbon Fiber Head Sets ***
UTVINC Rugged Radio Helmet Radio Kits (2) ***
UTVINC Trailing Arm UHMW Sliders ***
UTVINC Steering Column Wobble Delete ***
UTVINC Steering Column Extension ***
UTVINC 60 amp Distribution Box ***
UTVINC Optima Battery ***
UTVINC Optima Battery Box Conversion Kit ***
UTVINC Oh-Chit Anti Rattle ***
UTVINC Bed Heat Shield ***
UTVINC LED Turn Signal Kit ***
UTVINC Fan Over Ride Kit ***
UTVINC Security Alarm ***
UTVINC Fire Extinguisher ***
UTVINC Billet Fire Extinguisher Mount ***
UTVINC Billet Shifter ***
UTVINC Billet Shifter Handle ***
UTVINC Billet 1.25 Tow Hook ***
UTVINC Billet Grill ***
UTVINC Billet Air Intake ***
UTVINC Billet Clutch Intake ***
UTVINC Billet Dome Lights (2) ***
UTVINC Billet Crazy Lights (2) ***
UTVINC Billet Headset Hanger ***
UTVINC Billet Radio Cord Mount ***
UTVINC Billet Rear View Mirror ***
UTVINC Billet Side Mirrors (2) ***
UTVINC Billet Key Fob ***
UTVINC Billet Tilt Handle ***
UTVINC Billet Cup Holders (2) ***
UTVINC Billet Parker Pumper Mount ***
Lowrance GPS ***
CBR Radiator ***
Racer Tech XP 4 Complete Weld In Gusset Kit ***
COGNITO SHOCKS 2.0 Front & 2.5 Rears ***
COGNITO SWAY BAR ***
COGNITO RADIUS RODS ***
COGNITO A-ARMS WITH UNIBALL'S ***
Holz Upper Front Gusset Plate ***
Holz Billet Motor Mounts ***
Holz 300 M Alloy Rear Axles ***
Holz HD Front Axles ***
Holz Remote Oil Filter ***
NRG Quick Disconnect Steering Hub ***
Grant Steering Wheel ***
(5) Hiper Lite Dakar Duel Bead Lock Wheels 3 X 5 X 14" (Black & Machined Finish) (MIDWESTUTVCUSTOMS) ***
(5) Mongrel Tires 28 X 10 X 14" DOT Approved Tires (MIDWESTUTVCUSTOMS) ***
(4) Hiper Lite Side Winder Single Bead Lock Wheels 3 X 5 X 12" (Black & Machined Finish) ***
BRUNOMOTORSPORTS Custom Embroidered "APEX" 40" Rigid LED Lightbar Cover ***
STM BILLET CLUTCHES ***
TAGTEAM OIL COOLER ***
TAGTEAM APEX CONVERSION KIT ***
__________________
Basically cognitos bitd car would be what i would want
New XP LE 4 with EPS converted to a 2 seater with Apex power...
Cage with (2) Grab Handles & (3) Tab Mounts & 40" LED Light Mount
1 Piece Roof
Etched Carbon Fiber Roof Liner
Fire Extinguisher
Etched Carbon Fiber Door Liners
5 pt. Harnesses
Heated Seats
Seat Lowering Bases
HD Tie Rods
Parking Brake
Sun Visors (2)
40" Rigid Series E
Full XP Gusset Kit
Parker Pumper
Radio Stack Rack
G-Force Helmets (2)
Rugged Radios 50 Watt with 686 Intercom
Steering Column Extention
60 amp Disturbution Box
Optima Battery
Oh-Chit Anti Rattle
Bed Heat Shield
LED Turn Signal Kit
Fan Over Ride Kit
Security Alarm
Billet Shifter
Billet Grill
Billet Air Intake
Billet Door Handles
Billet Custom Dash
Billet Key Fob
Billet Tilt Handle
TAGTEAM Oil Cooler
Lowrance GPS
CBR Radiator
COGNITO SWAY BAR
Holz Hi-Clearance A-Arms
Holz HD Front Axles
ALBA Hi-Clearance Radius Rods
BMP 18 Gallon Fuel Cell
STM BILLET CLUTCHES
I was just talking to a guy yesterday building the same thing!
teryx 4 chassis(keep it a 4 seater), awd, z1 turbo arctic cat engine like queen racings center seat car, or zx14 turbo. 18-22" travel, center pivot front a arms. multi link rear. coil and bypass at all corners, 30" tires and a good set of STU's and wilwoods at each wheel.
UTVINC 1 Piece Roof
Lowrance GPS ***
CBR Radiator ***
__________________
UTVINC 1 Piece Roof
Lowrance GPS ***
CBR Radiator ***
Updated list...
