Yamaha clutch on 08 Rhino not engaging
mosslager
My buddy called me and said he unloaded his 2008 Rhino from his trailer and the clutch is not engaging. He revs it up and its not until its rapping out it starts to engage. Worked fine the last time out. Any ideas? He sent me a video from his phone I will try to post.
check the belt,
if belt is good, he may need to check to see if a roller is stuck in the sheave.
next the wet clutch may be bad (worn shoes)
next the teeth could be stripped on the primary shaft.
check the belt,
solid prognossis
