- Let me share some hard numbers with you. Awhile back, I was talking to Mark (Queen) about his front suspension, and learned that he runs a 350# over 450# spring set up, for a combined primary spring rate of 400 lbs./inch, and a secondary rate of 450 lbs./inch.
yesis this the formula you would use??
Primary Spring Rate X Secondary Spring Rate / Primary Spring Rate + Secondary Spring Rate. = Act. Spring Rate
Reid you aren't calculating the combined rate properly
A good baseline number which represents the pounds of force that either of the front corners of your car would see at full bump is roughly the total weight of your car. This is based on a worst case scenario where you hit a g-out, at speed, unexpectedly. The math is pretty basic, and is based on an impact force of 4-5 g's (hence, the total load being around the total weight of your car. A 1,600 lb. car, assuming GVW is perfectly distributed, weighs 400 lbs. at each wheel/corner, times 4-5 g's, equals 1,600 or 2,000 lbs. respectively at the center of the wheel). An impact like this will cause shaft speeds of the shock to exceed 100 feet per second!
Your question poses a great example of why I like to design my suspensions with as low a shock motion ratio as possible (stroking a longer travel shock, and using lighter, lower rate springs). The mounting "brackets" or tabs for the shocks can be much lighter, and therefore easier to fit in a given space when the shock is not over worked.
Let me share some hard numbers with you. Awhile back, I was talking to Mark (Queen) about his front suspension, and learned that he runs a 350# over 450# spring set up, for a combined primary spring rate of 400 lbs./inch, and a secondary rate of 450 lbs./inch. He is running the +3 1/2" lonestar kit if I'm not mistaken, and it utilizes a stock length shock, and stock location upper shock mounts. Assuming 18" of wheel travel stroking a stock length shock at 8.375" for a .46 motion ratio, and 1/3 of bump is realized at ride ht., each shock mount will be preloaded with 1,350 lbs. static load at ride ht. and a whopping 3,600lbs. at full bump!
Compare that to our 2015 RZR Xp4 1000 Monster Energy class 1900 UTV weighing in at just under 2,000 lbs., with 17.5" of front wheel travel stroking a 12" shock at a .69 motion ratio, and a spring set up of 150# over 250# for a primary rate of 200 lbs./inch, and a secondary rate of 250lbs./inch, and you get much lower figures. At ride height, the static load on the shock mount is 800 lbs., and the total load at full bump is 2,800 lbs. That is 800 pounds less at each corner that the shock mounts have to support, on a car weighing approx. 200 pounds more than its competitor!
So, some simple math says that car "A" (Queen Racing) weighs 20% less than car "B" (The Monster Energy XP4), yet sees 23% more loading on the shock mounts at full bump! God, I love math! It doesn't lie or manipulate. Only tells things exactly as they are!
The 2 valuable lessons here are:
1) Spring rate and wheel rate are two entirely different things, and:
2) As leverages upon springs/shocks are increased, the end results (loading upon a specific member or structure) are not directly proportional to the change in leverage, but rather inversely proportional to it. Kind of analogous to that compounding interest loan I took out when I bought my first new truck in 1982!
So, the question of the day is: Given the loading at each corner, how will you determine the thickness, design, and bracing the shock mount will need to repeatedly sustain impacts as described above with out failing, or pre maturely fatiguing? Simplest solution would be to input your data into an interactive application such as Solid Works, then multiply the results by 1.25 "Overkill is the key to success" (a phrase I coined in 1989 after building a heavier class 8 than most).
Ah yes! I love taking my brain for a walk!
