2009 Rhino Maintenance Quesiton
Rhino_Zimp
Hi somewhat new to this site. Anyone have opinons on better engine/differential oil Brands/Weights to use? And which brands/oil weights not to use. I ride mainly in glamis and out at the river (parker, az).
Thanks, I tried using the search option but its not letting me pull up anything...
hi tim in my rhino i use a castrol semi synthetic 10/40 oil ,and on the diff is the gl-4 ,you can also use amsoil full synthetic on all you fluids but the cost will be higher ,where in placentia do you live?
Thanks for the reply Tom. I will prob try that. My rhino seems to be heating up and melting the air duct assembly and the yamaha shops have never seen/heard of it... so i'm trying to get an idea of what others use for fluids and what not. What type of coolant do you run?
I live near Yorba Linda/ Valencia area...
i use a 50/50 blend of coolant ,we should get together for some rides i live just down the street by valencia hs
Splat onzipper
