2001 F250 7 3 diesel bogs down
If the tubes are hooked up they are good. If the cam sensor is bad it wont run. Accel pedal could be it but a good scanner can easily check this unless it is intermittent. Is it down on power all the time or just that one time?
Now is down on power - we are going to clean all the tubes and install new rubber
and going to install new CPS + the new Pedal with both new sensors ;-)
This usually causes a misfire type condition which doesn't seem to be the issue he is having
Yeah some for sure but they are gutless . Im obviously guessing but them harnesses are a common problem.
I had it once when my truck was under warranty and they had an upgraded gasket. No issues since then.
They can test the under valve cover Harness. sometimes they wiggle loose and make contact again and sometimes they will leave you stranded.
Is it fixed yet
Sent from my SM-G935T using Tapatalk
Still working on it - I ordered the inter-cooler boot kit for it, but after we took it apart we found out it has a Banks system on it and had to order the boots and clamps from Banks + we found some vacuum lines that are bad had to order them from Ford and the intake boots and clamps from Ford ;-(
Thank You for asking ;-)
