I agree Nate, I measured the clearance and made a piece that is a snug fit between the frame cross member and the drive shaft, so I will be able to do a "go / no go" type check easily. I wondered about fabbing a strut to fit between the trans case and the head that would help keep them from moving. Also now that I have a set of shocks that work good, the car doesn't bottom out like it did so that should help some. Thanks again for your input, it was spot on as usual.
