VIAIR UTV On Board Air System
VIAIR
Viair Corporation - UTVUnderground Approved
VIAIR UTV OBA p/n 10002 (prefect for UTV's)
QUARTER DUTY
P/N 10002
12-Volt
Permanent Magnetic Motor
Duty Cycle: 25% @ 100 PSI
Max. Working Pressure: 150 PSI
Max. Amp Draw: 18 Amps
2.0 Gallon Tank Fill Rate
0 To 120 PSI 2 Min. 22 Sec.
90 To 120 PSI 46 Sec.
Part Included in p/n 10002
- 2.0 Gallon VIAIR Air Tank
- 275C VIAIR Air Compressor
- Accessory Airline
- Pressure Switch (90 PSI on, 120 PSI off)
- 40 - Amp Relay
- 1/4†NPT Drain Cock
- 1/4†NPT Compression Fitting
- 145 PSI Safety Valve
- 20-ft. 12 Gauge Wire
- Inline Fuse Holder
- Electrical Connections
Bump it up! The Magnum boys have been quoting systems out all week! Hit up Magnum Offroad for your new VIAIR system!!
I am hoping to get my truck on the lift in the next 2 weeks to install. I want to have it all in before vegas 2 reno!
