UTV Truck Style Tires
Beadlock wheels list >>> http://www.utvunderground.com/forum/index.php?threads/utv-beadlocks.20785/
Arisun Raceline After Shock XD AR33
28x10R14 - 8 ply - 16mm Lugs - 34.1 lbs
28x10R15 - 8 ply - 16mm Lugs - 33.0 lbs
30x10R14 - 8 ply - 16mm Lugs - 37.4 lbs
30x10R15 - 8 ply - 16mm Lugs - 36.3 lbs
32x10R14 - 8 ply - 16mm Lugs - 37.4 lbs
32x10R15 - 8 ply - 16mm Lugs - 37.3 lbs
http://psatireandwheel.com/tires.php?tire=aftershock
Arisun Raceline Gear Buster AR63
28x10R14 - 8 Ply - 18mm Lugs - 34.1 lbs
30x10R14 - 8 Ply - 18mm Lugs - 36.3 lbs
30x10R15 - 8 Ply - 18mm Lugs - 35.2 lbs
http://psatireandwheel.com/tires.php?tire=gearbuster
BFGoodrich Baja T/A KR2 UTV Tire
30×9.5R15 - 37 lbs
https://www.jacksonmotorsportsgroup.com/utv
Carlisle VERSA Trail ATR
27x9R12 - 6 ply - 19mm Lugs - 26.8 lbs
27x11R12 - 6 ply - 19mm Lugs - 30.9 lbs
27x9R14 - 6 ply - 19mm Lugs - 27.1 lbs
27x11R14 - 6 ply - 19mm Lugs - 31.6 lbs
28x10R14 - 6 ply - 19mm Lugs - 32.1 lbs
28x12R14 - 6 ply - 19mm Lugs - 34.9 lbs
29x10R15 - 6 ply - 19mm Lugs - 33.0 lbs
http://www.carlislebrandtires.com/our-products/product-detail/versa-trail
CST Behemoth
27X9R12 - 8 ply - 19mm lugs
27X11R12 - 8 ply - 19mm lugs
27X9R14 - 8 ply - 19mm lugs
27X11R14 - 8 ply - 19mm lugs
28X10R14 - 8 ply - 17mm lugs
28X10R15 - 8 ply - 17mm lugs
30X10R14 - 8 ply - 17mm lugs
30X10R15 - 8 ply - 17mm lugs
BEHEMOTH REAR CU08 | Side-by-Side Tires | CST Tires
CST Clincher
27X9R12 - 6 ply - 20mm lugs
27X11R12 - 6 ply - 20mm lugs
27X9R14 - 6 ply - 20mm lugs
27X10R14 - 6 ply - 20mm lugs
27X11R14 - 6 ply - 20mm lugs
28x10R14 - 6 ply - 20mm lugs
CLINCHER REAR CU04 | Side-by-Side Tires | CST Tires
CST Dingo
27x9R12 - 8 ply - 15mm lugs
27x11R12 - 8 ply - 15mm lugs
27x9R14 - 8 ply - 15mm lugs
27x11R14 - 8 ply - 15mm lugs
28x10R14 - 8 ply - 15mm lugs
28x10R15 - 8 ply - 15mm lugs
29x9R14 - 8 ply - 15mm lugs
29x11R14 - 8 ply - 15mm lugs
30x10R14 - 8 ply - 15mm lugs
32x10R14 - 8 ply - 15mm lugs
32x10R15 - 8 ply - 15mm lugs
http://www.csttires.com/us/atv/sxs/dingo-cu47/
CST Lobo
27X10R12 - 8 ply DOT - 13mm lugs
27X10R14 - 8 ply DOT - 13mm lugs
28X10R14 - 8 ply DOT - 13mm lugs
28X10R15 - 8 ply DOT - 13mm lugs
29X9R15 - 8 ply DOT - 13mm lugs
30X10R14 - 8 ply DOT - 13mm lugs
30X10R15 - 8 ply DOT - 13mm lugs
32X10R14 - 8 ply DOT - 13mm lugs
32X10R15 - 8 ply DOT - 13mm lugs
32X10R16 - 8 ply DOT - 13mm lugs
http://www.csttires.com/int/atv/sxs/lobo-ch01/
CST Lobo RC
30X10R14 - 8 ply - 13mm lugs
32x10R14 - 8 ply - 113mm lugs
33X10R15 - 8 ply - 13mm lugs
35x10R17 - 8 ply - 13mm lugs
http://www.csttires.com/us/atv/sxs/lobo-rc-ch68/
Discount Tire Rage STORM (Right)
27X9R12 - 8 ply DOT - 17mm lugs - 30.3 lbs
27X9R14 - 8 ply DOT - 17mm lugs - 30.4 lbs
27X11R12 - 8 ply DOT - 17mm lugs - 36.3 lbs
27X11R14 - 8 ply DOT - 17mm lugs - 36.0 lbs
28X10R14 - 8 ply DOT - 17mm lugs - 34.4 lbs
Rage Tires Storm tires listed by size
Discount Tire Rage THUNDER (Left)
27X9R14 - 8 ply DOT - 17mm lugs - 27.5 lbs
27X11R14 - 8 ply DOT - 17mm lugs - 32.0 lbs
28X10R14 - 8 ply DOT - 17mm lugs - 32.6 lbs
28X10R15 - 8 ply DOT - 17mm lugs - 32.2 lbs
30x10R14 - 8 ply DOT - 17mm lugs - 34.4 lbs
30x10R15 - 8 ply DOT - 17mm lugs - 33.9 lbs
http://www.discounttiredirect.com/direct/tires/rage_tires/product/byName.do?tmn=Thunder&typ=ATV
DURO Power Grip M/TS
29x10R15 - 8 ply DOT - 13mm lugs -
30x10R14 - 8 ply DOT - 13mm lugs - 37.4 lbs
DWT Moja-V
28x9-14 - 8 ply (40.1 lbs) & Run Flat (47.9 lbs)
28x11-14 - 8 ply (46.5 lbs) & Run Flat (53.1 lbs)
30x10-14 - 8 ply (49.3 lbs) & Run Flat (58.2 lbs)
8 ply & 12 ply Run-Flat
http://dwtracing.com/product/new-mojave-run-flat/
EFX MotoClaw
27x10R14 - 8 ply DOT - 1" (25mm) - 37.6 lbs
28x9R15 - 8 ply DOT - 1" (25mm) - 34.6 lbs
28x11R15 - 8 ply DOT - 1" (25mm) - 38.0 lbs
29x10R16 - 6 ply DOT - 1" (25mm) - 39.9 lbs
30x10R14 - 8 ply DOT - 1" (25mm) - 41.8 lbs
32x10R16 - 8 ply DOT - 1" (25mm) - 46.0 lbs
33x10R18 - 8 ply DOT - 1" (25mm) - 49.3 lbs
EFX MotoClaw - All Terrain, Radial ATV Tire and UTV Tire by EFX Tires
EFX MotoHammer
27x9R14 - 8 ply DOT - 19mm - 28.8 lbs
27x11R14 - 8 ply DOT - 19mm lug - 36.3 lbs
28x10R14 - 8 ply DOT - 19mm lug - 33.7 lbs
30x10R15 - 8 ply DOT - 19mm lug - 38.4 lbs
31x10R14 - 8 ply DOT - 19mm lug - 41.8 lbs
32x10R16 - 8 ply DOT - 19mm lug - 40.2 lbs
EFX MotoHammer Radial DOT All-Terrain ATV & UTV Tire
EFX MotoVator
28x9.5R14 - 8 ply DOT - 19mm lug - 36.5 lbs
30x9.5R14 - 8 ply DOT - 19mm lug - 41.5 lbs
30x9.5R15 - 8 ply DOT - 19mm lug - 40.0 lbs
30x9.5R16 - 8 ply DOT - 19mm lug - 38.8 lbs
http://www.wheelprospowersports.com/tire/3402/motovator-(steel-belted-radial)
EXCEL TIRE | AMS M1 EVIL
27X9R14 - 8 ply DOT - 1" (25mm) - 34.1 lbs
27X11R14 - 8 ply DOT - 1" (25mm) - 36.7 lbs
28X10R14 - 8 ply DOT - 1" (25mm) - 37.0 lbs
30X10R14 - 8 ply DOT - 1" (25mm) - 39.7 lbs
32X10R14 - 8 ply DOT - 1" (25mm) lugs - 42.0 lbs
https://www.exceltireandwheel.com/m1-evil.html
Fuel Off Road Mud GRIPPER UTV
28x10R14 - 8 ply DOT - 21mm Lugs - 41.0 lbs
30x10R14 - 8 ply DOT - 21mm Lugs - 45.3 lbs
30x10R15 - 8 ply DOT - 21mm Lugs - 43.1 lbs
http://www.fueloffroad.com/utv/tire/3095/gripper-utv/
GBC Dirt Commander
27x9-12 - 8 ply - 21mm - 25.0 lbs
27x11-12 - 8 ply - 21mm lug - 29.3 lbs
27x9-14 - 8 ply - 21mm lug - 24.6 lbs
27x11-14 - 8 ply - 21mm lug - 29.4 lbs
28x10-12 - 8 ply - 18mm lug - 29.1 lbs
29x9-14 - 8 ply - 21mm lug - 27.9 lbs
29x11-14 - 8 ply - 21mm lug - 33.8 lbs
30x10-14 - 8 ply - 21mm lug - 33.8 lbs
30x10-15 - 8 ply - 21mm lug - 38.0 lbs
32x10-14 - 8 ply - 21mm lug - 38.2 lbs
GBC Motorsports
GBC Kanati Mongrel
27x9R12 - 10 ply DOT - 16mm lug - 27.2 lbs
27x11R12 - 10 ply DOT - 16mm lug - 30.9 lbs
27x9R14 - 10 ply DOT - 16mm lug - 26.5 lbs
27x11R14 - 10 ply DOT - 16mm lug - 29.8 lbs
28x10R14 - 10 ply DOT - 16mm lug - 29.6 lbs
28x10R15 - 10 ply DOT - 16mm lug - 28.7 lbs
30x10R14 - 10 ply DOT - 16mm lug - 33.3 lbs
30x10R15 - 10 ply DOT - 16mm lug - 34.0 lbs
32x10R14 - 10 ply DOT - 14mm lug - 39.6 lbs
32x10R15 - 10 ply DOT - 14mm lug - 40.0 lbs
GBC Motorsports
Gladiator ATR
28x10R14 - 8 ply DOT - 16mm lugs
30x10R14 - 8 ply DOT - 16mm lugs
30x10R15 - 8 ply DOT - 16mm lugs
32x10R15 - 8 ply DOT - 16mm lugs
http://gladiatortires.com/tires/atv-utv/atv-atr/
GMZ Cutthroat
28x10R14 - 6 ply DOT - 19mm lug - 30.9 lbs
Cutthroat Tire
GMZ Ironman
30x9.5R15 - 8 ply DOT - 40 lbs
32x9.5R15 - 8 ply DOT
http://www.gmzraceproducts.com/index.php/ivan-ironman-stewart-edition-by-gmz
GMZ Kahuna
30x10R14 - 8 ply DOT - 16mm lug - 32.7 lbs
30x10R15 - 8 ply DOT - 16mm lug - 32.2 lbs
GMZ Race Products - UTV/SXS Kahuna Tire
Goldspeed MU900
28x8R15 - 6 ply - 26.5 lbs
28x10R15 - 6 ply
http://www.goldspeedproducts.com/shop/goldspeed-mu900-utv-tires/
Goldspeed Gravity 845
30X10R14 - 8 ply DOT - 30 lbs
http://www.goldspeedproducts.com/shop/gps-gravity-845-utv-tires/
Goldspeed Gravity 1046 Limited Edition
30x10R14 - 10 ply OEM Certified & Approved
http://www.goldspeedproducts.com/shop/10-ply-gravity-1046-utv-tire-30x10x14/
ITP Blackwater Evolution
27x9R12 - 8 ply - 1" (25 mm) lugs - 26.5 lbs
27x11R12 - 8 ply - 1" (25 mm) lugs - 30.3 lbs
27x9R14 - 8 ply - 1" (25 mm) lugs - 27.8 lbs
27x11R14 - 8 ply - 1" (25 mm) lugs - 31.8 lbs
28x10R12 - 8 ply - 1" (25 mm) lugs - 31.8 lbs
28x9R14 - 8 ply - 1" (25 mm) lugs - 29.8 lbs
28x10R14 - 8 ply - 1" (25 mm) lugs - 31.9 lbs
28x11R14 - 8 ply - 1" (25 mm) lugs - 33.0 lbs
30x10R12 - 8 ply - 1" (25 mm) lugs - 36.0 lbs
30x10R14 - 8 ply - 1" (25 mm) lugs - 33.3 lbs
30x10R15 - 8 ply - 1" (25 mm) lugs - 33.8 lbs
32x10R15 - 8 ply - 1" (25 mm) lugs - 36.8 lbs
34x10R17 - 8 ply - 1" (25 mm) lugs - 39.9 lbs
Tires - Blackwater Evolution
ITP UltraCross R
27x10R-12 - 8 ply
27x9R-14 - 8 ply
27x10R-14 - 8 ply
28x10R-12 - 8 ply - 31.1 lbs
28x10R-14 - 8 ply - 34.3 lbs
29x9R-14 - 8 ply
29x11R-14 - 8 ply
29x10R-15 - 8 ply - 35.5 lbs
30x10R-14 - 8 ply - 35.5 lbs
30x10R-15 - 8 ply
31x9.5R-14 - 8 ply
31x9.5R-15 - 8ply
32x10R-15 - 8 ply - 39.8 lbs
34x10R-17 - 8 ply
Tires - Ultracross Rspec
Maxxis Carnivore
28x10R14 - 28.7" ø - 8 ply DOT - 22mm Lugs - 29 lbs
29x9.5R15 - 29.7" ø - 8 ply DOT - 22mm Lugs
30x10R14 - 30.5" ø - 8 ply DOT - 22mm Lugs - 33 lbs
32x10R14 - 32.0" ø - 8 ply DOT - 22mm Lugs - 36 lbs
32x10R15 - 32.4" ø - 8 ply DOT - 22mm Lugs
http://www.maxxis.com/catalog/tire-552-111-carnivore
Maxxis Coronado
27x9R14 - 8 ply - 20mm lug
27x11R14 - 8 ply - 20mm lug
28x10R14 - 8 ply - 20mm lug
30x10R14 - 8 ply - 20mm lug
Coronado | Maxxis USA
Maxxis Liberty
28x10R14 - 28.5" ø - 8 ply DOT - 13mm Lugs
29x9.5R15 - 29.7" ø - 8 ply DOT - 13mm Lugs
29x9.5R16 - 29.0" ø - 8 ply DOT - 13mm Lugs
30x10R14 - 30.4" ø - 8 ply DOT - 13mm Lugs
32x10R14 - 32.0" ø - 8 ply DOT - 13mm Lugs
32x10R15 - 32.4" ø - 8 ply DOT - 13mm Lugs
32x10R18 - 32.4" ø - 8 ply DOT - 13mm Lugs
http://www.maxxis.com/catalog/tire-517-111-liberty
Maxxis Rampage
30x10R14 - 30.3" ø - 8 ply - 15mm Lugs
32x10R14 - TBA - 8 ply - TBA
32x10R15 - TBA - 8 ply - TBA
http://www.maxxis.com/catalog/tire-555-111-rampage
No Limit Patriot
Tusk Warthog
27x9R14 - 8 ply - 21mm Lugs
27x11R14 - 8 ply - 21mm Lugs
28x10R14 - 8 ply - 21mm Lugs
28x10R15 - 8 ply - 21mm Lugs
29x9R14 - 8 ply - 21mm Lugs
29x11R14 - 8 ply - 21mm Lugs
30x10R14 - 8 ply - 21mm Lugs
30x10R15 - 8 ply - 21mm Lugs
No Limit Patriot & Tusk Warthog are the exact same tire with different names.
https://nolimitwheels.com/product/patriot-terrain-tire/
https://www.rockymountainatvmc.com/p/723/69017/Tusk-Warthog-Radial-Tire?term=tusk tire
PIT BULL Braven-Ironside
27X9R14 - 8 ply DOT - 15mm lugs - 27.0 lbs
27X11R14 - 8 ply DOT - 15mm lugs - 32.2 lbs
28X10R14 - 8 ply DOT - 15mm lugs - 32.7 lbs
30X10R14 - 8 ply DOT - 15mm lugs - 35.5 lbs
30X10R15 - 8 ply DOT - 15mm lugs - 36.0 lbs
32X10R14 - 8 ply DOT - 15mm lugs - 40.5 lbs
32X10R15 - 8 ply DOT - 15mm lugs - 39.9 lbs
http://www.pitbulltires.com/product-p/brbravenironsideutvparent.htm
Pro Armor Crawler Dual-Threat
29X9R14 - 10 ply - 16mm lugs - 31.5 lbs
29X11R14 - 10 ply - 16mm lugs - 35 lbs
Pro Armor Crawler XG | Moto Race Tires CRAWLER “X ROX DD”
30x10R14 - 8 ply DOT - 20mm Lug - 39 lbs
32x10R14 - 8 ply DOT - 20mm Lug - 42 lbs
Moto ?X Rox DD? ATV/ UTV Race Tire | MotoRaceTire.com
Crawler XG 14" Tire Pro Armor
Pro Armor Crawler XR | Moto Race Tires CRAWLER "RACE"
28x10R14 - 8 ply DOT - 13mm Lug - 29 lbs
30x10R14 - 8 ply DOT - 13mm Lug - 32 lbs
32x10R15 - 8 ply DOT - 13mm Lug - 36 lbs
Moto ?Race? ATV/ UTV Race Tire | MotoRaceTire.com
http://www.polaris.com/en-us/rzr-side-by-side/shop/accessories/pro-armor-crawler-xr-tire/pid-5415536
Pro Armor Hammer | Moto Race Tires HAMMER "SUMMIT"
30x9.5R15 - 8 ply DOT - 19mm lug - 36 lbs
Moto ?Summit? ATV/ UTV Race Tire | MotoRaceTire.com
Hammer 15" Tire Pro Armor
http://www.polaris.com/en-us/rzr-side-by-side/shop/accessories/pro-armor-hammer-tire/pid-5415615
QuadBoss QBT846 Radial
27x9R14 - 8 ply DOT - 19mm lugs
27x11R14 - 8 ply DOT - 19mm lugs
28x10R14 - 8 ply DOT - 19mm lugs
30x10R14 - 8 ply DOT - 19mm lugs
30x10R15 - 8 ply DOT - 19mm lugs
32x10R15 - 8 ply DOT - 19mm lugs
http://www.quadboss.com/atv-sport-utility-mud-tires.html
QuadBoss QBT446
27x9R12 - 8 ply - 19mm Lugs
27x9R14 - 8 ply - 19mm Lugs
27x11R12 - 8 ply - 19mm Lugs
27x11R14 - 8 ply - 19mm Lugs
30x10R14 - 8 ply - 19mm Lugs
Sedona Rock-A-Billy
28x10R-14 - 8 ply - 32.0 lbs
30x10R-14 - 8 ply - 36.4 lbs
http://www.sedonatires.com/product/rock-a-billy
STI Chincane RX
27x10R14 - 27.2" ø - 8 ply DOT - 16mm lugs - 30.0 lbs
28x10R14 - 28.1" ø - 8 ply DOT - 16mm lugs - 31.7 lbs
30x10R14 - 30.2" ø - 8 ply DOT - 16mm lugs - 37.4 lbs
30x10R15 - 30.3" ø - 8 ply DOT - 16mm lugs - 36.5 lbs
31x10R14 - 31.0" ø - 8 ply DOT - 16mm lugs - 38.0 lbs
32x10R15 - 32.1" ø - 8 ply DOT - 16mm lugs - 42.0 lbs
http://stitireandwheel.com/product/chicane/
STI Euduro XT/S
28x9.5R14 - 28" ø - 8 ply DOT - 16mm lugs - 39.0 lbs
30x9.5R14 - 30" ø - 8 ply DOT - 16mm lugs - 39.0 lbs
30x9.5R15 - 30" ø - 8 ply DOT - 16mm lugs - 39.0 lbs
32x10R14 - 32" ø - 8 ply DOT - 16mm lugs - 39.0 lbs
http://stipowersports.com/product/enduro-xts/
STI Roctane XD
27x9R14 - 27.2" ø - 8 ply - 22mm lugs - 28.6 lbs
27x11R14 - 27.5" ø - 8 ply - 22mm lugs - 31.9 lbs
28x10R14 - 28.3" ø - 8 ply - 22mm lugs - 37.3 lbs
30x10R14 - 30.4" ø - 8 ply - 22mm lugs - 42.4 lbs
32x10R14 - 32.3" ø - 8 ply - 1" (25 mm) lugs - 53.3 lbs
34x10R15 - 34.0" ø - 8 ply - 1" (25 mm) lugs - 56.0 lbs
http://stitireandwheel.com/product/roctane-xd/
STI Roctane XD-K (Kevlar)
27x9R14 - 27.2" ø - 8 ply - 22mm lugs - 34.0 lbs
27x11R14 - 27.5" ø - 8 ply - 22mm lugs - 39.7 lbs
28x10R14 - 28.3" ø - 8 ply - 22mm lugs - 44.1 lbs
30x10R14 - 30.4" ø - 8 ply - 22mm lugs - 48.5 lbs
http://stitireandwheel.com/product/roctane-xd-kevlar/
STI Roctane XS
28x10R14 - 28.0" ø - 8 ply - 19mm lugs - 33.8 lbs
29x10R15 - 29.4" ø - 8 ply - 19mm lugs - 34.1 lbs
30x10R14 - 30.2" ø - 8 ply - 19mm lugs - 37.8 lbs
30x10R15 - 29.9" ø - 8 ply - 19mm lugs - 34.1 lbs
30x10R17 - 30.2" ø - 8 ply - 19mm lugs - 36.0 lbs
31x10R17 - 30.9" ø - 8 ply - 19mm lugs - 36.0 lbs
Roctane XS | STI Tire and Wheel | ATV/UTV Tires & Wheels
Tensor Regulator A/T
28x10R12 - 8 ply DOT - 15mm Lugs - 38.8 lbs
28x10R14 - 8 ply DOT - 15mm Lugs - 36.4 lbs
30x10R14 - 8 ply DOT - 15mm Lugs - 38.6 lbs
30x10R15 - 8 ply DOT - 15mm Lugs - 38.6 lbs
32x10R14 - 8 ply DOT - 15mm Lugs
32x10R15 - 8 ply DOT - 15mm Lugs
https://tensortire.com/collections/frontpage/products/the-regulator
32x10R15 - 34 lbs
Tensor DS
https://tensortire.com/collections/frontpage/products/tensor-ds-race-tire]
TUSK Terrabite
27x9R12 - 8 ply DOT - 18mm Lugs - 29.4 lbs
27x11R12 - 8 ply DOT - 18mm Lugs - 32.7 lbs
28x10R14 - 8 ply DOT - 18mm Lugs - 33.1 lbs
30x10R14 - 8 ply DOT - 18mm Lugs - 35.7 lbs
https://www.rockymountainatvmc.com/p/723/60312/Tusk-Terrabite-Radial-Tire
Sweet post! I always ran the Goldspeed stuff on my quad but i can't find their UTV stuff and the link seems broken. Anyways the MXU is the only tire i found on their site for 25x8x12, 25x10x12, 26x9x12 an 26x11x12 unless you guys have seen any more?
