ROCK READY
THE IQ3RZR DASH FROM UTVRACEPAK - $825.00
High performance instrumentation for your RZR! The IQ3RZR Dash from UTV Racepak replaces the factory gauge with a rugged, pre-programmed digital display which connects seamlessly to the factory ECU, providing engine information, GPS speed, heading and time data. Plus, add additional inputs to monitor belt temperature, oil pressure and more with available Racepak sensor kits. The optional custom dash panel, in black gel coat, can be finished to match your RZR and uses factory mounting locations. Give your RZR the edge in instrumentation!
IQ3RZR DASH FEATURES:
·Four pre-programmed RZR ECU data display pages
·Park, Reverse, Neutral, Low, High position display
·GPS Speed, Heading & Time display
·High Beam, 4WD indictors
·Engine Warning messages
·Programmable warning indicators
·Rear mounted factory ECU connector
·Rear mounted GPS connector
·Rear mounted V-Net connector (for additional sensor inputs)
·Shielded anti-glare coating for sunlight viewing
·Blue backlight
Shown with optional dash panel. Factory switches not included.
