Yamaha Top speed?
littlegrande
Little Grande
My 660 tops out at 64 MPH
45mm hsr mikuni Carb
Trinity dual exhaust
Has had engine work (previous owner. Don't know what)
So what does yours top out safely at?
Sent from my C5170 using Tapatalk
64 is moving for a Rhino 660!
Nate
Alba Racing
The Carb and exhaust are the only visible thing that I can see on it. Don't want to take the head off just to measure the cylinder. I don't ride with anyone to get a base to compare to :/
If you are doing 64, then it likely will have head work, piston and cam and a clutch sheave. It probably is a 686.
my 06 686 was right at 62 on GPS
like said,, 64 is very good for the rhino
if that's from the speedo, they usually clock a little fast
You definitely have motor work. I had an '08 with an MSD and greaseless weights and barely broke 50 on the gps.
Mine has been 63 with my 720 .. its got more left but maybe 1-2mph but i get scared holdin it down that long cause she's singin at those speeds
60mph
check out my Rhino Getin Wet
<iframe width="640" height="360" src="//www.youtube.com/embed/ay9vC2v6ayM" frameborder="0" allowfullscreen></iframe>
My 660 stock motor, hot rod greaseless, black rhino cdi, muzzy exhaust, uni filter, and bed delete....does 59 on the dash, gps says 61...not sure which is correct, so i go with 60mph...but if you ask any of my friends "not fast enough"...LOL
Mine would hit 64 before the piston and cam swap. This video is with my daughter in there with me and me trying to film the gps. With my 26" tires the dash showed 62 and the gps read 64.
<iframe src="//www.youtube.com/embed/ODg-IcCkdmA" allowfullscreen="" frameborder="0" height="315" width="560"></iframe>
This is after my 11:1 piston and Stage3 cam. It would hit the rev limiter at 61mph but get there much faster.
<iframe width="560" height="315" src="//www.youtube.com/embed/QKrvmhvhyxM" frameborder="0" allowfullscreen></iframe>
That is very impressive. Was that on a paved road?
My rhino before my motor work with just a carb, sheave and black rhino cdi would hit 50 to 53 on a flat dirt road. Any of the 660 rhinos I have been with do not see mid/upper 50s or low 60s without motor work.
The JBS sheave must allow the belt to really ride high and get more top speed.
it was on a flat dirt road...i havent been able to do a paved road run...i bought this rhino the way it is, the guy i bought it from says the motor is stock...he seemed truthful and the rhino was VERY well taken care of, with receipts for oil changes and regular maintenance....everyone that has been in it, have been surprised, and most of my friends think its got a 686 and im just BS'ing them...but in reality, i was just told it was stock...so who knows?...
<iframe width="560" height="315" src="//www.youtube.com/embed/yrFeJIw4X48" frameborder="0" allowfullscreen></iframe>
I bet your motor has work done to it. Either way that is moving in a rhino.
KpALMA
