marktorres
I am pretty certain I have a bearing that is near failing in my front diff; when I look at the part diagram the hub, bearing and a bushing are sold as an assembly though.
Has anyone seen a rebuild kit or do you know the dimensions of the bearings and if they can be pressed off of the hub? I would think I could have a new bushing turned out if it is worn and still come out cheaper than the $450 I'd need to do it with OEM parts.
I will likely take mine apart and experiment but if anyone knew I would certainly appreciate any help.
Thanks!
Mark
Thanks!
Mark
