So I have a 2013 XP900. My rear camber was starting to look way out to the negative...10 degrees or so it looked like. I never did check it with the angle finder before putting on new lower high clearance radius arms. I set my new radius arms to spec at the heims eye to eye and it looked great. I went to Pismo this weekend and after a day of riding I was cambered out again and the ass was sagging to about 10" of GC. I came home and checked my camber was at 5 degrees fully drooped. I set it at 0 degrees and added a half inch of preload to the rear springs as they seem to be sagging. I am at 4" of distance vs the 3.8" per Polaris specs now if you follow the user manuals measuring guide of point A to B (rezzie bracket to bottom of the lower coil retainer nut). My rear radius arms are now eye to eye at 24" even which is about 5/16 inch short compared to the stock lower radius arms eye to eye. I figure they will settle in nicely. But this is what it took to get my GC back and camber to look normal after 650 miles of use. Anyone else seeing the same type issues? Also, will I have binding issues through the full suspension cycle by shortening up the radius arms by 5/16"? I was not able to cycle it without removing the shocks and ran out of time for that.
