Rugged RaceAce Dual Antenna
RuggedRadios
Always have race communications! Rugged introduces the RaceAce switch able dual antenna. The RaceAce provides the best in communications with a 5/8 wave Ground Plane antenna and a ½ wave No Ground Plane antenna with the exclusive Rugged Switch Box.
Go the distance with the 5/8 wave antenna mounted on a roof with a good ground plane. The 5/8 antenna supplies superior transmission wave pattern from front to back and side to side. Mounted on a proper 3’ by 3’ or larger ground plane (roof) the 5/8 wave antenna will transmit further than ¼ wave and ½ wave antennas.
In the event of a roll over or the roof mount antenna is broken off simply switch the Rugged Switch Box to antenna 2. Let the low mounted ½ wave no ground plane antenna take control. The ½ wave no ground plane antenna does not require a large roof surface so they can be mounted in a lower protected position.
Rugged keeps you connected even when the race takes a tough turn!​
we've been testing one of these on the Genright KOH buggy for about a month now and are very happy with the way it works!!!
If you haven't picked up one of the RaceAce antenna Kits already now is the time to do it. We are ready to ship today.
S&S Development
