Rigid Industries Releases Innovative New LED Light; The Single Row Mini
BlackRhinoSteven
Rigid Industries, the world leader in cutting edge forward projecting L.E.D. technology, announces their newest product, the Single Row Mini, or SR-M. The SR-M combines a new lightweight, compact design with the same ultra efficient patented optic systems Rigid Industries is known for. The new light was engineered and designed for a simple installation that allows for mounting in nearly any application.
Rigid Industries has once again revolutionized the way the world sees at night, this time in the smallest and lightest fixture we have ever produced, the Single Row Mini. Encased in a magnesium housing, the light weighs in at an astonishing 7 ounces, including hardware. At 3 inches wide by 1.75 inches tall, the SR-M fits in the palm of your hand. The hybrid spot optic in the SR-M will project light nearly 1000’; while the specter optic will produce an unbelievable 1050 raw lumens. The SR-M will also be available with a diffusion lens, a feature that separates the beam of light outwards at a 60-degree angle, allowing for brilliant area lighting.
“The Single Row Mini is something all of us at Rigid Industries have been dreaming about since day oneâ€, says Rigid Industries VP of Sales and Marketing, Taylor Anderson. “To create an extremely compact light that is highly efficient yet remarkably bright is an engineering feat. We are very proud to say this dream is now reality and available to the public through our network of dealers and distributors.â€
High-powered LED lighting has never come in a smaller more efficient package. The SR-M draws as low as 0.63 amps and can run on any 7 to 36 volt system. The light comes with the Rigid Industries limited lifetime warranty and world famous customer service.
The Single Row Mini will also be available in Marine Grade, under our M-Series family of lights. This includes a 3 stage durable UV 3800 powder coat, ASTMB117 Salt/Fog and IP68 certifications as well as stainless steel hardware. The M-Series SR-M will be available mid to late May.
A Flush Mount version of the SR-M, in both marine and standard housings, will be available in late May as well. The flush mount brings efficient lighting to applications where space or appearance is a concern. The flush mount option allows for a whole new look while also adding flexibility during installation. All you need is a flat surface and the ability to wire to it
The M-Series SR-M will be available mid to late May at Black Rhino
Hickoryjoe
